I have been given an avol arc-l01 tv. doesn't work in tv mode
I have been given an avol arc-l01 tv. cannot get it to work on tv mode. it does not pick up the channels. and has no place for antanae.
3 Suggested Answers
  • 208 Answers
SOURCE: avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Posted on Mar 21, 2010
Testimonial: "indeed, thx 4 ur time"
  • 5161 Answers
SOURCE: 26" ILO digital T.V . won't pick up digital
So called digital antennas are generally a gimmick. The important factor to receiving stations is the antenna position and strength relative to the incoming signal. (Digital signals are either enough for the tuner or you get "no signal".)
Look at antennaweb.org or tvfool.com to find out what stations are likely to be received in your area and the direction to rotate the antenna; plug your address in the search area. Antennaweb is very conservative in its channel list even though it assumes an external antenna. Tvfool gives a list of the channels you should get with various antennas (labelled by color). This is a standard label that will be on the antenna specs or box (at least on good antennas). Tall buildings and trees in the area can reduce the channels you receive.
Adding an amplifier may help you gain signal strength for borderline stations (or if you split the signal to several devices).
I hope this helps.
(My house has an external antenna with an amplifier/splitter. Antennaweb suggested that we'd only get the stations from ~10 miles away. We get those stations and the ones from ~30 miles away with the antenna rotated for the further stations.)
Posted on Sep 11, 2010
What is REMOTE CODE FOR AVOL ARC-W15 ?
0426 0433 0465 0601 0616. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 21, 2014 | Televison & Video
Reset the remot control for AVOL tv
If you have a an Avol AET3220FD and the remote control ARC-U1 (this is the universal remote that comes with the tv) stops working follow the following steps.
1) Hold tv button until it goes solid red
2) type 523
3) press set button
4) then click power button to check and see if the remote will work.
Feb 03, 2013 | Televison & Video
Avol mod#alt2260m remot code
I have an avol lcd tv. my tv is not operating with remote and have no remote code remote is ARC-U1 tv model is ALT2260M. Please tell me hoow to apply code and which code is ti be applied on the remote.
Dec 09, 2012 | Televison & Video
Where can i purchase a AVOL tv remote (ARC-U1)
http://www.avukltd.uk.com/index.php?osCsid=2158210173a162a6756e86f81fb6fa3b
Nov 25, 2011 | Televison & Video
Avol tv. What is direct tv remote codes for programing remote to tv
Try using the brand "Hisense"....worked for my Avol.
Sep 02, 2011 | Televison & Video
Need Remote for AVOL t.v
go to www.AVL21c.com this is the company that makes the AVL Brand televisions for AAFES
Aug 17, 2008 | Sony RMT-V202 Remote Control
Avol TV remote
I own an AVOL 19in TV, I just got my comcast cable hooked up; I too was plagued by initially having to use my other remote to turn TV/volume on/off up/down. Being the code is not listed in the Comcast universal remote instructions, in the above answers someone mentioned APEX as a parent company with AVOL; I was able to use a code from the APEX codes listed in the Comcast universal remote instructions to get the controller to work with turning the TV power on/off and volume control. The code that worked for my particular TV was 10765. Try these codes for your TV to see if they work- 10748, 10879, 10767, 10890. Hope this helps.
Mar 17, 2008 | Televison & Video
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Electro Med Services...
