Your fix could be as simple as cleaning the camera's battery contacts,
or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak
Help Center by clicking on the link below. It uses a simple Q&A
format to diagnose problems and propose solutions.
got droped now when turn on get pink fuzzy lines in veiwing area may go away if tap on hand but by...
(More)
got droped now when turn on get pink fuzzy lines in veiwing area may go away if tap on hand but by time try to focas gets fuzzy again.if stays clear still will take a good pic.
When I turn the camera on (with new batteries), it flashes green for a second or two, then flashes...
(More)
When I turn the camera on (with new batteries), it flashes green for a second or two, then flashes red and will not turn on. What is the issue? Thank you.
Camera won't show any pictures on the screen but will show from sd card taken from another camera....
(More)
Camera won't show any pictures on the screen but will show from sd card taken from another camera. It will flash and you can hear it click but no picture.
