Question about Nokia 6205 Cell Phone
Phone doesn't charge
Third phone that doesn't work with same problem - won't charge.
  • melissazharr Jul 14, 2009
    I believe it is the charging portal - it may be broken because they already verified that it wasn't my charger or my battery.
  • Pjethaliya May 11, 2010
    battery problem may be there
  • 518 Answers
MAYBE THE CHARGER IS FAULTY, TRY SOMEONE ELSES CHARGER
Posted on Jul 14, 2009
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
It won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 01, 2012 | Casio Cell Phones
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Is there a way I can charge my iphone when my home button and charger won't work?
Try taking it in to an apple store. Given the age of the phone, there may not be anything they can do to assist. Unfortunately, unless you try your luck with a third-party phone repair company, you will need to find a new phone.
Dec 08, 2017 | Apple iPhone Cell Phones
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Mar 03, 2012 | Motorola Mobility T505 Handsfree...
While i was trying to update my nokia n73 turned off and now i can't turn it on,and my pc doesn't recognize when i connect the phone turned off
Did the update finished with out an error?check your battery,if the battery is too drained,you won't able to charge the phone.If this method doesn't works,there's a problem on the update process.
to be able to retrieve your phone,ask assistance to a mobile phone service near you.they will glad to assist you on your problem..
Jun 12, 2011 | Nokia N73 Cellular Phone
My Samsung phone has no power, won't accept a
The battery is most likely at fault, though if a different battery still doesn't work, there's probably something else to blame.
May 20, 2011 | Samsung Cell Phones
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 6205 Cell Phone Logo
114 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
