Question about Bladerunner Toys
How do I adjust Bladerunner Pro adjustable inline skates?
How do I adjust Bladerunner Pro adjustable inline skates to a larger size? These children's skates adjust from size 9 to 12. They belonged to an older sibling and the manual is missing.
4 Suggested Answers
SOURCE: Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Posted on May 10, 2009
  • 51 Answers
SOURCE: i just bought barbie adjustable inline skates from
their is usually 2 plastic prongs or knobs on th bottom side where the skates connect squeeze them together and pull the skate out or upward
Posted on Jun 04, 2009
skaterkid307
  • 86 Answers
SOURCE: Bladerunner Pro 78W skates hurt my ankles when skating
The padding on the inside of the rollerskate boots may not be enough padding for exellent comfort. Go to your rollerblade brand website and buy new inside boots, or Check out all outdoor stores in your location.
Posted on May 30, 2010
Which Inline Skate is better for women?
Roller Derby Women's Inline Skate is constructed with a reinforced-polymer frame that makes it sturdy and usable for a long period of times. Comfortable boot support system places your boot at the exact place that helps you a good skating.Click here for full details of Roller Derby Women's Inline Skate.
Jun 05, 2018 | Video Game Consoles & Games
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
How do I adjust the size on the ABEC 7 Schwinn inline skates?
get the directions from their web site and follow them
Oct 13, 2014 | Cycling
I need to convert these training skates to inline skates
Buy a set of training wheels, install them on skates. Also, look in the diaper aisle for training pants. Put them on outside of your pants, so people will know your "training" thus stay out of your way.
Aug 30, 2014 | Generic Chicago Skates Boys Training...
I trying to adjust rollerblade sizes and it doesn't work
u should but a smaller/ bigger pair of rollerblades
Feb 18, 2013 | Sport & Outdoor - Others
Need to know how to adjust tone arm and anti-skate
Get one of those little mini-digital scales that should sell for about $30 or less. Make sure it reads in 0.1 or 0.01 increments. Unplug the turntable (so the platter doesn't spin) and place the scale in the tonearm path. Most tonearm and headshell combos should work well in the 1.0 to 1.5 g range. Weigh the tonearm balancing on the scale about midway through the path (where it would be in the center of the record)
I used a flat plastic credit size card to protect the stylus on the surface. Don't forget to tare the scale to 0. Attempt to calibrate your weight scale adjustment on the tonearm to match the scale while you are at this. Once you have found a setting that works for you, match that marking on the weight scale adjustment on the anti-skate wheel.
You should have a turntable that sounds nice and is also gentle on your records!
Feb 18, 2013 | Audio Players & Recorders
How do you adjust the memory anatomoic fit ******** the boot of the Roller Derby Spartan Z-9-9 mens inline skate?
You have to lock the silver tab all the way back (it will click and lay flat). You have to keep that down with your thumb. There are two black plastic levers which hold the ratchet strap in place. You have to press them down towards the boot (not together towards the strap). When they are new this is a bit difficult. You may have to do one side at a time (just remember to keep the metal tab in its laid back position or it will snap shut and you will have to start all over again). Once you have the lever stop checks above the ratchet bevels of the strap, you will be able to pull the strap back out. Open and close the strap a few times to get the "new" out of it and it will function fine.
Jan 02, 2011 | Roller Derby Mens Spartan 9.9 InLine...
May 30, 2010 | Bladerunner Pro XT In Line Skate Women
I just bought barbie adjustable inline skates from a second hand store but i don't have instructions on how to adjust them. can you help?
Jun 04, 2009 | Bravo Sports Barbie: Junior Skate Combo...
Toys Logo
709 people viewed this question
Top Bladerunner Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Bladerunner Toy Expert? Answer questions, earn points and help others
