Question about Toro Lawn Mower With Toro Power Tools
My toro lawn mower starts and run properly for about 5 to 10 minutes then it dies and cannot be restarted until the next day
  • 10,865 Answers
Your carbeurator is partially blocked. Either rebuilt the carbeurator or install a new one.
Posted on Jul 14, 2009
Toro personal pace 20372, starts fine, runs well for 30 or 40 minutes then dies. Starts up again when cooled down just a bit.
Need fuel that is not more than a couple months old
Need a good or clean spark plug
Have no idea how old it is, or how many years
you have used it
Sometimes you have to remove the head & clean the
carbon off the piston & head
That is a tune-up on small equipment
Make sure the air filter is clean
They usually start with the air filter off,but you don't
want to do that all the time
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
My mower is four or five years old and has done well, but now when it is used it runs great for about fifteen minutes and then sputters and dies. When it does this it will not restart until it cools
The oil level is low. when the oil drains from the engine it fills the base to the level of the sensor. When it runs it takes a little time for the oil level to drop below the sensor..........Hope this helps.
May 20, 2011 | Toro Lawn Mower With Toro Power Tools
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Sep 28, 2008 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
410 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
