Question about Fellowes DM15C Shredder
Shredder won't turn off
At first cleaning the sensor works. Now nothing works except unpluging or turning the power off
    Problem Solver:
  • 19 Answers
The sensors probably need replacing. Most larger Fellowes shredders come with a three year warranty. It will not hurt to use it the way you are using it.
Posted on Jul 19, 2009
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
Black n& DEcker paper shredder CC600 will not turn on
Check if there is power from the outlet. Check the cabling. Then do a check on the shredder to see nothing is blocking the free movement of the "knives " then check if all sensors are engaged. Not closing the shredder 100% ant the not closed sensor will prevent the motor to run. See and here if the paper in sensor is in tact and clicking when putting in paper. Needless to say, you better unplug the shredder when you open it to check.
Apr 18, 2015 | Black & Decker CC600 Shredders
Why won't shredder turn off automatically?
turn off and unplug; then turn over to see if there is any paper jammed in the shredder. MAKE SURE YOU TURN OFF AND UNPLUG BEFORE YOU WORK ON IT.
Clean out any jammed paper or plastic with a bamboo skewer or something like that. DO NOT put YOUR HANDS near the blades.
Jul 15, 2014 | Destroyit 2603 SMC Shredder
Fellowes HD-10Cs won't shred. Power gets to machine because it will manually reverse when reverse button held. Can't get the sensor lights to work. Tried overide switch for sensor light. Held in...
Unplug from mains electricity.
use a cotton bud dipped in rubbing alcohol to clean the sensor
light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Jan 31, 2014 | Fellowes HD-10Cs Shredder
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
Oct 23, 2009 | Royal 150MX Cross-Cut Shredder
SHREDDER NOT TURNING
Does it reverse? Can you hear any motor noise? If it does then try cleaning the upper and lower sensors with cotton swab. If it does not reverse, then remove the top and check for jams or broken gears.
Jun 10, 2009 | Office Depot Ativa DQ60M Shredder
Fellowes DM15C Shredder Logo
241 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
