Question about HP LaserJet 3330 All-In-One Printer
Hp laser jet 3330 will not reset with acquired instructions and bulb warming message stays on.......i've tried to unplug unit....stays the same. cancel button also stays lit
    President:
  • 2,306 Answers
You need to take apart the top and clean the scanner bulb and mirrors, if cleaning does not help then you need a new scan assembly. Usually costs more than a new machine.
Posted on Jul 14, 2009
Won't go to menu
Had a similar problem on a HP MFC3330
Fixed it with the following video aid:
"how to fix the scanner bulb warming up error hp 3330 or repair 3380 scanner bulb warm up problem - YouTube"
http://youtu.be/lqG_nmi3vC4
Hope it helps...
Jul 27, 2014 | Dell 1600n All-In-One Laser Printer
My hp laserjet 3330mfp reports a scanner bulb is warming up and it never goes off. I have tried to unplug then plug back in. The printer works fine.
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Oct 20, 2010 | HP LaserJet 3330 All-In-One Printer
Hp laser jet printer 3330 instruction manual
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=18972&prodSeriesId=66359&lang=en&cc=us#2
Sep 12, 2010 | HP LaserJet 3330 All-In-One Printer
My HP Laser Jet 3330 keeps sending pop-ups and PRINTS out a message with the headline: HP LASERJET DIRECTOR: shortcuts and more..This occurs every time I start (boot?) my new Compaq CQ5110F PC with Vista...
Sounds like you have a software or driver conflict. Go to hp.com Support & Drivers and check to make sure you have the correct driver for Vista. Even if you do, try uninstalling and reinstalling the driver.
Also, while at hp, check for the latest Firmware update. Go to the printers menu and scroll to INFORMATION (or REPORTS). Select that sub-menu, then scroll to PRINT CONFIGURATION PAGE. Select thi and print out the page. Look for what is beside Firmware Datecode. If it is older than what is on the hp website, print out the instructions for installing the update.
Apr 30, 2010 | HP LaserJet 3330 All-In-One Printer
Hp 3330 laser jet memory low error when faxing
1)Press ENTER/MENU
2)Simultaneously PRESS then RELEASE * then # to enter Developers Reset(This is a soft reset. No loss of data or configuration settings).
3) Press < or > button until the message REINIT FFS appears on the second line of the control panel.
4) Press MENU/ENTER.
5)Takes about 2.5 minutes.
6) When READY appears on display press CANCEL to exit.
Apr 02, 2010 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 MFP
I have that oranage triangle light blinking as warm up message continues I also had power loss I have taken the plug out and will wait a while and try again. I still get now scanner errors using ubuntu..
May 16, 2009 | HP LaserJet 3330 All-In-One Printer
HP LASER JET 3330
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Apr 05, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
310 people viewed this question
Seeker5211
Seeker5211
