Question about Maytag PYE2300AY Electric Dryer
Dryer dead! Nothing happens when the start button is pressed. The door switch operates the light inside the dryer on / off.
  • rorrinita May 11, 2010
    My dryer is dead. If the thermal fuse is the cause, how can we test it? We also found another switch by the blower completely cover with lint, the p/n is listed as 53-2880 but I can't find any information on this switch to find the name of it and to see how it functions.
  • 52 Answers
You have a bad fuse. Will probably have to have a repairman replace it. It is hard to get to
Posted on Jul 15, 2009
I change the belt now when press start nothing happens the light inside dryer does not shut off
It sounds like you have a three wire door switch on that dryer and you have hooked the wires up incorrectly on the door switch or the switch is just bad one of the two.
Sep 16, 2015 | Whirlpool WED8300S Dryer
Samsung Dryer DV665JW has no Power. I already checked the plugs and Breaker system, they are okay but nothing happens when I press the power button. It is 4 years old. Is it worth repairing ?
First, when you say "no power", is the front panel display totally dead? If so, and you're sure 240v is getting to the back of the dryer where the power cord connects, then its most likely the main board has been blown--did you have a power outtage recently? They are notorious for damaging circuit boards. If the dryer lights up but won't do anything when you push the start button, check the door switch--it's a safety feature that won't allow the dryer to run with the door open. There are also thermal fuses inside which, if open, will kill the power. BTW, yes, the dryer is worth fixing--the cost of a repair won't be near what a new dryer will be.
Aug 14, 2015 | Samsung Dryers
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Nothing happens when you press start
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
May 20, 2009 | Dryers
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Dryer won't run
take a look at your start and door switch
May 24, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
215 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
