Question about Dell PowerVault 110T DLT VS160 DLT Tape Drive
Both Fault and Clean lights are on - Dell PowerVault 110T DLT VS160 DLT Tape Drive
    Scholar:
  • 41 Answers
It is nearly impossible to make a guess about a hardware fault without any additional information. The most common problem I know of though, is using a cleaning tape too many times. After about 2o uses, they pretty much don't clean anymore. If it's possible that you think you're cleaning the heads, but using too old of a cleaning tape, you may want to replace it. Otherwise, a hardware fault will have to be looked at internally.
Posted on Jul 27, 2009
Clean fuel sensors
https://www.youtube.com/results?search_query=t+2002+Jaguar+X-Type++Clean+fuel+sensors 2002 Jaguar Type Clean fuel sensors YouTube
Sep 16, 2014 | 2002 Jaguar X-Type
Clean Pump light keeps coming on
What is the model number of your unit?
Nov 10, 2012 | Washing Machines
Kudx03ftss2 clean light flashing
you have a heater fault if the light is flashing 7 times and then pause. to clear the fault perform a key dance of HEATED DRY - NORMAL 2 times, or HIGH TEMP - AIR DRY 2 times. this will start a diagnostic cycle that will clear the fault. if the fault continues to return you may need to call for service.
Jan 23, 2012 | KitchenAid Dishwashers
66515919001 dishwasher doesn't finish washing. clean light flashes
The clean light is flashing due to a fault in heating the water properly. See the link below to reset the control so you can use the dishwasher and what might have caused it. Let me know if this was helpful.
Clean Light Flashing
May 28, 2010 | Kenmore Dishwashers
Turn singles work in the back but not in the front or hazard lights and the fog lights dont come on fuse is good and flasher is good
the haz switch may be at fault which is the only common link in the turn signals and hazard, but if the fogs dont work you may have a common earth lead running the front lights so trace that and clean, as fogs are not attached to the turn signals if the earth is not the fault trace fault on each as separate problem, fogs should be only working when your drinving lights are switched on
Dec 05, 2009 | 1998 Pontiac Firebird
Clicking sound
The clicking sound is the park interlock solenoid. Haven't figured out why this should be connected to the fault that I think you have, which is an earth fault on your rear lights. Go to your rear light clusters and find the black earth wires and trace them to where they bolt to the bodywork, check they are clean and tight. If OK, likely to be an internal fault in the light cluster - check neither of them have water ingress. Check soldered connections are good and contacts are clean. This may solve the clicking interlock problem - it sounds like they are related, but just not sure how without a very long look at the circuit diagram.
Jul 18, 2009 | 2002 Jaguar X-Type
Clean light flashes and dishwasher wont start
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Dec 23, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashing
The clean light should be blinking 7 times, pause, then repaeat if it is doing this -- it is a water heating fault. Use one of the following key dances to clear fault
a) Heat Dry - Normal - Heat Dry - Normal
b)High Temp-Air Dry-High Temp-Air Dry
All the Leds should light up now just press cancel and Unit should operate. If it shuts down again the heater isnt working properly. Some times the door doesnt get shut well and that causes the fault. But the dishes arent very clean if the heater is not working.
Oct 16, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Dell PowerVault 110T DLT VS160 DLT Tape Drive Logo
1,102 people viewed this question
Alun Cox
