my wireless adapter keeps disconnecting me from the internet, and I can't figure out how to fix it. I have to restart the computer everytime. I also can't pick up my laptop or it freezes. I have a toshiba.
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this. and your laptop is freezing because you might not have got it serviced from a very long time.
i was using windows xp then after i reformat it to windows xp service pack 2, i dont see any...
(More)
i was using windows xp then after i reformat it to windows xp service pack 2, i dont see any wireless connection on my laptop. all i have is a lan. and when i check my device manager at the netword adapter only the "realtek blah blah is in there"? wth
BT have tried remotely to connect me to the wireless broadband, they advise me that there is a fault...
(More)
BT have tried remotely to connect me to the wireless broadband, they advise me that there is a fault with the wireless adaptor
i have a toshiba equium p200, its vista, the wireless used to not function, but i downloaded the...
(More)
i have a toshiba equium p200, its vista, the wireless used to not function, but i downloaded the atheros network driver, this sorted this. however now the wireless works intermittently with either me having to disable/enable the device to restart the connection or reboot the laptop. qit just seems to suddenly not recognise the wireless, the physical switch at the front works fine. help! its really annoying!
I would like to know how to open up the laptop solely to change the battery as i cannot boot up and...
(More)
I would like to know how to open up the laptop solely to change the battery as i cannot boot up and changing the battery was the recommended course of action.
if any one can give me pointers so that I can find out which screws to undo and any sequence necessary to remove the bottom cover I would appreciate it.
Many thanks.
Andrew.
