Question about Hayward 1.5 Hp Northstar High Performance Pump
Conversion of electric motor from 230 to 110. set by manufa.
Motor is set for 230 and needs to be switched to 115 power supply. Motor is emerson 1.5 hp 2 speed model r636xdri239
    Sergeant:
  • 368 Answers
I suggest modifying your wiring to 230 V. More information is needed to guide you through this but you could go to one of the home improvement stores and sometimes they have people in the electrical department that can help you to guide you through. They can also sell you wire a 230 V breaker that you may need. In order to do this you need to make sure that all the wires and equipment are connected according to the NEC. Good luck and remember to turn power off when you are working on it. You might also check to see if your municipality allows you to do work on your electrical system.
Posted on Aug 28, 2009
  • 128 Answers
Can't be done.
Posted on Aug 23, 2009
I have a Ingersoll Rand Compressor model# 2545E10V 10 HP,3 phase and I would like to convert it to a signle phase. would this motor here be good to go with and what other items will be needed to complete...
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
Mar 05, 2015 | Ingersoll Rand Air Tools & Compressors
No power to the blowermotor
You should always include the device in which it is installed since there are several possibilities that may influence the supply of AC voltage to the motor.
Some items can also be eliminated if you have a simple multimeter available at home.
These can be bought at electronic supply and auto parts stores for under $20 US- don't spend more, additional features or improved accuracy aren't necessary for most tasks.
Mar 27, 2013 | Emerson BlowerMotor, PSC, 1/2hp, 1075,...
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Belt will not turn
1) Please go to under wood and put your work your software calibration under the hood and follow the step, for diagnostic and fix it.
2) Adjust the reed switch by 1/8"
3) tight the connector from display board vs lower board (main motor board(
4) Measure 115 Vac for input to main motor board.
5) Measure for +5Vdc for output for main motor board, to input to display board.
6) Measure 115 Vca for main motor without load.
7) Test the circuit breaker or fuse.
8) Test the power supply coming from transformer for +5vdc.
sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua.
Dec 25, 2011 | Reebok Exercise & Fitness
Used my Bostich CAP2000P for total of less than 2 hours. (not continuous). Now it won't start, have 115 volts at switch, 115 volts at motor. replaced regulator switch. Does not smell of any electrical...
If the motor cover was removed to test power there and it is there. Check for electric continuity across the motor with the power leads disconnected. If the motor is electrical open, find the open or replace the motor.
Inside the motor is a thermal overload motor protection device, it may be defective
Aug 29, 2017 | Stanley FactoryReconditioned Bostitch...
Need wiring schematic for a 115 volt install
THERE ARE THREE SCREWS 1 AT ONE O-CLOCK(GOUND) THE OTHER 2 AT THREE O-CLOCK.ARE THE LINES(POWER). THE CAN GO ETHER WAY ! YOU WILL NEED TO SET THE SWITCH OR WIRES TO 115 V POSITIONmotorwizj_0.jpg LOOK ON THE MOTOR LABEL IT TELLS YOU HOW TO SET IT UP . HOPE THIS WAS OF HELP. IF IT WAS CLICK ON THE YES HELPFUL BUTTON .. THNX... JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 13, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
I have a 1hp 115/230 phase 1 sprinkler pump what size pressure switch do i need 20/40 or30/50 ?
The pressure switch needs to be sized for the pressure and the motor current. The pressure would depend on your piping system, and hao many sprinklers you have on a section. You can buy a pressure switch that is adjustable, and you can set the pressure you need. You also must be sure the current rating (amps) of the pressure switch can handle the motor current (amps) there are is a wide range of switches available. You can't go wrong with a square d though. Available Home Depot, graingers, electrical supply etc.
Jul 03, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Why does my pool motor keep burning out? I have replaced 2 new ones since march. I have a haward super pump and Emerson 2 hp motor
What is your line voltage to the motor; 115 or 230? The motors come out of the box at 230 if it is dual voltage and if you are connecting it to a 115 V line, it will overheat and eventually fail.
If you are connecting it to the correct line voltage and setting the motor to match; check to be sure your voltage is not dropping under load. Check both line to ground to ensure both lines are sound.
When replacing the motor, are the seals sound or have you replaced the pump seal at all? Is it leaking?
Are the motors failing electrically or mechanically?
Sep 26, 2009 | Water Warehouse HIGH PERFORMANCE 2 HP...
Hayward 1.5 Hp Northstar High Performance Pump Logo
213 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
