Question about Tape Decks
Tape deck won't open
I placed a tape in a deck that I haven't used in a long time. It wants to auto rewind and I noted other post on "tape deck inoperable" but I can't eject the tape to get the tape out. Any ideas?
  • 22 Answers
Re: tape deck won't open
Try turning the flywheel in the direction of rotation and see if the cassete door sudenly opens easy. Norm K.
Posted on Oct 15, 2008
  • 79 Answers
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Posted on Mar 15, 2008
0 characters
3 Points
Why does my deck not play in reverse?
check for a broken rubber band for the rewind spindle
bands available from Jaycar in packs
Nov 08, 2015 | Tape Decks
Denon DRM 740 tape does not play
hmmm...sounds like the transport motor/foot are it up, and inspect around those items(where the tape actually clamps down) and see if you can see anything in there. Might even be a bug, no fooling..
as to are most likely talking some major money, and a long time in the repair depot, which I believe is in Rio..I'll check that for you while you do this part.
Mar 16, 2008 | Denon DRM-740 Single Dual Cassette Deck
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Tape Decks
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Tape Decks
Old Teac A601R not working, when you place a tape in it just stops automatically. Is it worth trying to find out what's wrong or is it to old. When you place in a tape and press play it goes forward then...
The unit can be fixed in the right hands. The auto rewind function might be on but the reel rotation sensor is not seeing it move. Probably needs all new belts.
Sep 16, 2013 | Teac Tape Decks
The play, rewind switches won't stay down
I have advised people before that replacing belts is not the only answer and sometimes people that are not experienced can upset some part of the deck without knowing it. We don't yet know the model or brand of the unit and from the description this kind of points to a Piano key or lever key type deck. I could also be a cam system deck. This complaint of buttons not staying down would not apply to a tack switch or solenoid type transport.
Like Jerry says a visit to a good Tech is the answer. I have been doing tape decks for 40 years and have worked at Sony and Teac service shops. If you need my help let me know. I am near Chicago.
Jul 20, 2012 | Tape Decks
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Tape Decks
Cassette deck won't play, fast fprward, rewind. Automatically shuts off
The tape deck must be in need of a belt kit replacement. Difficult to get and even more difficult to replace.
Sep 26, 2011 | Tape Decks
Sony TC-K690 3Head Cassette Deck - no playback
It needs a new rubber belt for the mechanism control.
It is a smallest of th 3 rubber belts.
Mar 14, 2010 | Sony Tape Decks
Dual tape deck inoperable
clean the rubber pinch rollers with an alcohol swab. the tape is not getting required "grab" on these rollers and not pulling tape. the auto reverse is an attempt to rewind the tape because of confusion with no tape movement.
Nov 12, 2007 | Yamaha KX-W321 Single Cassette Deck
Tape Decks Logo
206 people viewed this question
Top Tape Decks Experts
Gyula Lacz
Bruce Showalter
Are you a Tape Deck Expert? Answer questions, earn points and help others
