Question about Nokia 6070 Cellular Phone
The screen comes to message mode and gets stuck automatically
How to i disable DOS mode
Hi - Is this definitely a Mac? Usually being stuck in DOS only happens with non-Macs.
If a mac, could you tell me what you're seeing on screen while in "DOS mode". for example, screen color, text color, any messages or prompts?
Thank you - I'll be on the lookout for your reply
Apr 15, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
Sir my pc has automatically restart and does not worked proprely they can give the fatal error plzz helpp me
Are you getting a Blue Screen error and can't read it because the computer keeps restarting?
If So, turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Scroll down past safe mode and you will see an option to Disable Automatic Restart. The next time you boot up you will be able to see the error message.
If it is a Blue Screen Of Death (BSOD) error message, you might need a system disc.
Mar 26, 2012 | Dell OptiPlex GX620 PC Desktop
I have a black screen that says safe mode, safe mode with networkin , safe mode with command prompt and laast known good configuration but when i go to safe mode my computer just reboot all over again
This recycling/rebooting into this screen is normally caused an error (hardware or software).
You MUST turn off - Automatic Restart to see the error message.
Power down your laptop.
Press the power button to turn-on laptop.
Start pressing the F8 key immediately AFTER the DELL logo screen and BEFORE the windows screen.
You SHOULD be brought to the same screen as you described above but with an additional option: TURN-OFF automatic restart. Select this option and press ENTER.
Let laptop cycle and you should see blue background screen with white letters giving you information.
Please provide the ERROR message on screen BEFORE we can advise you any further.
Mar 30, 2011 | Dell Latitude D600 Notebook
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
After (successful) restoration of desktop 838GM, boot-up get stuck at black screen with message that "NTLDR is compressed, press ctrl alt del to restart". When I do the ctrl alt del, computer reboots but...
The startup files are corrupted.You need to put the windows disk in the DVD and make the computer boot off that when it starts up. Booting off the DVD may need to be set in the BIOS if the machine does not do it automatically.
When the window comes up you select install windows.
Second option is repair my computer. Then follow the prompts.
Aug 12, 2010 | Gateway 838GM (RB838GM) PC Desktop
Toshiba laptop satellite L300 Booting Problem
try the recovery wizard,also try pulling the hard drive,and ram,and bios battery if you can get to it,looks like watch battery on motherboard.or green plastic pack with two wire plug on main board,take the panels off on the bottom,if your lucky you will see it,otherwise have to dissamble to get to it.if you find it unplug for a couple hours,with main battery out and ac unplugged,should reset the bios to factory default ,might help ,do you have xp or vista?if your bios battery is the watch battery style be very carefull removeing it the holder will break off the motherboard easily,,if none of that works post a reply and ill give you some more options
Sep 10, 2009 | Toshiba Satellite Pro L300 Notebook
Replace the PF KIT 1 On my MFC 8460 N
that refers to the automatic feed. in other words, your main paper cassette. the MP kit is for the manual bypass tray. if paper is feeding ok and your not having problems, you can reset the message by pressing "menu" " *2864" within 2 secs. now you are in maintenance mode. push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. press "stop/clear" to back out to maintenance mode screen. press "99" to exit maint. mode. do not mess with any other settings in that mode as you could render your machine inop. however, you may want to reset the "fuser life" while you are in maintenance mode "88" as both of these messages are supposed to come up at 100,000 pages. chances are unless you've had fuser replaced, that message will be coming up soon also.
good luck,
razors
Mar 25, 2009 | Brother MFC-8460N All-In-One Printer
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
Nokia 6070 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
