Question about Roxio Easy CD & DVD Creator Platinum Edition for PC
I am trying to burn a data disc using Roxio DE 9. The file is bigger than 700GB so I changed the option to enable disc spanning for data discs so it will let me us 2 cds to complete the download. When I click burn I am getting this error "the following files are larger than the size of your inserted media. Do you want to continue without these files? If I click no it doesn't do anything. If I click yes I get this "As a result of file errors on the previous screen, no files could be found to create your Archive disc. Any suggestions?
  • celestem74 Jul 14, 2009
    I did not mean to report this as and Abuse.
  • 4,806 Answers
Have you tried to burn a data DVD instead?
Posted on Jul 14, 2009
What is Power2Go and do I need it
That depends. What OS are you running? What type of files will you burn to disc (and what capacity disc)?
The program lets you burn various files to CD, DVD or BD. If you only plan on burning data files, you may not need it. If you burn ISO to create bootable CDs or DVDs, you might find it useful if you have XP. Windows 7 and 8 include a feature to correctly burn ISOs. (I don't remember if that feature is included in Vista.)
If you want to copy optical discs to burn backup copies, this software will also handle that. The Windows built-in software doesn't copy discs with DRM.
If you are compiling your own audio and video and then burning the resultant file to disc, the software is partially useful. (Another program has to do the compiling.)
There are other programs that do the same tasks as Power2Go. Roxio Creator (includes the video editing and playback software in addition to the burning unit) and Nero Burning ROM are commonly advertised options. A review of Power2Go with links to reviews of similar products is here: http://www.pcmag.com/article2/0,2817,2407197,00.asp .
I hope this helps. If you need additional information, please add a comment with your OS and file burning plans.
(I burn more ISOs and data files. Thus I use the Windows built-in software most of the time.)
Jun 24, 2013 | CyberLink Power2Go
What's the difference between burning a cd and burning an image
Burning an image file (ISO) means that you will burn and finalize the disc. The ISO file includes a "boot sector". This will create a disc that can be used as a boot CD. Make sure that the ISO is <700 MB if you burn to CD; if it is larger, use a DVD or DVD DL. Some image files may have an IMG file type (this was the file type for bootable floppies). Unless the file is an ISO or IMG, the burn image function will not work. You will need to use another program to make an image file first. You may need to use a bootable disc to get the information for the boot sector.
Burning a CD creates a data CD which may or may not be finalized, depending on your settings.
I hope this helps.
Mar 04, 2013 | Roxio Easy CD & DVD Creator 6...
I have downloaded the ISO file but not sure how to use it to install the windows 7 which is an upgrade version Many thanks
An ISO file is a CD or DVD image. You burn a disc with this image using a program like CDBurnerXP (a good, free program which is the one I use), or Nero or Roxio which often come preloaded on a system.
If the system has been set up correctly, ISO files should start the burner program for you when you double-click on one. Then you just need to have a disc in the burner and off it goes. Otherwise, you need to start the burning program manually and select the "burn an image" option. Specify the ISO file when you are asked for the image to burn. Do burn an ISO file to a disc using the "create a data disc" option. People often do this and then wonder why the result isn't correct.
Once you converted the ISO image to a real disc, you can either keep it or delete it.
Dec 04, 2010 | Microsoft Windows XP Professional
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Roxi create de 9 write data to dvd+ successfully but nothing on d
I would make sure that the disc is finalized. Most drives will not read data on a disc without it being finalized.
Sep 16, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Roxio help
download the latest version of roxio viz roxio creator 10 (if you dont have it) .. disc copier is available in that..
Jul 10, 2009 | Roxio Easy CD & DVD Creator Platinum...
Downloading a programn
If you have a DVD burner in your system, you probably have software that will allow you to burn disks already installed on your machine. The most common programs are Roxio, Sonic or Nero. I haven't used the Roxio software for a long time (since version 3), so I don't know how much as changed in its use. With Sonic or Nero, you just tell it what kind of disk you want to burn (for a program or data file, select data disc). Then add the files you would like to burn to the disk and click on the burn button. A few minutes later you will have a copy of your program burned onto the disk.
If for some reason you do not have any third-party burning software installed on your computer, you can insert a blank CD or DVD into the drive and when the autoplay options appear, select the option for having Windows prep the disk to burn files to it. Or you can even use Windows Media Player to do this too, but you would need to go into open up the Burn menu and select the Data CD or DVD option (instead of Audio CD).
Hope this helps!
May 27, 2009 | Microsoft Windows XP Home Edition
I have roxio creator & my dvd 9.0 de ; how do i burn my movies
I am trying to burn a movie onto a dvd using Roxio easy cd & dvd burning. The problem is that when I do burn it, it burns as a data disc. I try other things on it and it says to use the disc copier application to burn a dvd. I have searched everywhere on this progmram and there is nothing that says disc copier.
Jan 19, 2009 | Roxio Easy CD & DVD Creator Platinum...
Roxio Easy CD & DVD Creator Platinum Edition for PC Logo
502 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
