Question about Whirlpool Washing Machines
Cannot get cold water to come into the washer
I have a whirlpool washer and the cold water will only drip into the washer. I can only get very hot water to come out. When I put it on warm or cold, it buzzes, but only drips cold water. Any suggestions on what I can try?
  • 396 Answers
Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only cold water comes out of the unit when on hot temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
Posted on Jul 14, 2009
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
Why is the hot water pipe dripping after tighening up.
First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
Oct 28, 2014 | Washing Machines
I Have a cold water dripping in my sink the taps are mixer taps i have fitted a new washer but it still drips also it is tight to turn on and off. also my Hot water tap is hard to turn on it turns quite...
you need to check the seating in the tap for pitting, the new washer will not seal if the seating is pitted. you could fit some TAP REVIVERS which are available from most plumbers merchants.
Sep 08, 2011 | Home
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
Water is dripping into the machine when it is off.
Either the hot or cold water valve is not shutting off completely. It will need to be replaced.
Jun 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Dripping water from outlet in door that fills the washer
djam919,
Your water valve may be leaking. Can you tell if the water dripping is hot or cold?
Some washing machines have one dual valve for hot and cold water, and some will have separate valves. You must remove the top of your unit to find out if your have one or two valves.
To remove the top of the machine you need to remove 3 screws on the back of the unit at the very top, then the top should slide towards the back of the machine ( with a litle push ), now lift the top off the unit.
To determine what valve to replace first you must look on the back of you washer and locate the hot and cold connections, then shut off the one of the water lines coming to your machine at the wall valve, if it continue leaking then you can tell that the opposite valve is the problem. ( wait for about 10 min to make sure that the water leaking isn't just left over water in the hose).
Good Luck
check us out at www.CenturyApplianceRepair.com
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water drips in instead of fills. Hot water
Inlet screen in the hot water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 30, 2009 | Kenmore 22422 Top Load Washer
Water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Sep 05, 2009 | Whirlpool Washing Machines
Water Leak
take channel locks and tighten the hose connections going to the back of the washer
also tighten the connections going to the hot and cold water bibbs
remember turn to the right (clockwise to tighten
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Jan 10, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal De
