Question about Refrigerators
I have a side by side and the freezer keeps flling with water on the bottom and after that is full it starts to come out the door. this happens a little water at a time fills and freezes below
  • 21 Answers
DRAIN IS STOPPED UP DEICE WITH BLOW DRYER ,REMOVE BACK PANEL (IF NOT GE)USE TURKEY BASTER TO FORCE WARM WATER THROUGH DRAIN TO CLEAR AND CLEAN
Posted on Jul 15, 2009
Water line keeps freezing
turn your freezer control up almost all the way, and turn the refrigerator control down a little (tiny bit). this will slow the airflow  down in the back of the refrigerator near the water line.
Jul 06, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
We have a GE tfx22prxd aa side by side. There is water that runs out the bottom of freezer door. Happens about once or twice a day and leaves small puddle. There is a thin layer of ice laying on freezer...
Because the drain hole is probably frozen and the water can't drain out. Gain access to drain hose by pulling fridge out removing back cover and locating drain line. Remember how drain line is positioned and pull it off. Now open freezer door and pull the bottom container out and look toward the rear bottom of freezer. That's the drain. In order to fix it i usually melt the top part enough so i can start pouring hot water in it and be trying to clear with icepick too. When done reattach drain line and that's it.
Sep 25, 2017 | Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
