Question about TruTech TT320
How do you take progressive scan off
DVD player stuck on PROGRESSIVE SCAN, Tv screen black, can't view menu to change off progressive scan. HELP!
  • 5 more comments
  • Muckloo Nov 30, 2007
    Since the problem happened when I selected progressive scan on a menu, I tried the component video output and the S-video outputs with appropriate cables and a fairly new Sony TV. Audio was working and giving the background music for the main menu for my dvd. Only the component cables appear to be putting out a signal but it is unrecognizable and therefore I can not use any menus to turn off progressive scan.
  • bigwilly Dec 04, 2007
    no picture only audio , screen is blue and saya progressive scan mode
  • Rambo29561 Dec 29, 2007
    Same problem, can't find a key combination on remote to turn off progressive scan. My manual is 1000 miles away.
  • romelvice Feb 25, 2008
    ¿como detener progresive scan de un dvd digix modelo HT-1056a?
  • Anonymous Aug 17, 2008
    Had the same problem - pressed "shift" and ">>>" (aka "p.scan" key) at same time. Did it a bunch of times and eventually it worked. Not happy with design, because of course this all happened in the middle of a film festival. Grumble.
  • sherrycake Jan 21, 2009
    I have the same issue. Called the company and they said they have no solution and to return it but I don't have my receipt anymore.
  • Anonymous Mar 06, 2009
    i activated the PAL system selection from the menu, now I can't get it back to normal. Just a blank screen on my TV with the message "Invalid Format" on the screen. I pressed every button on the remote, unplugged the DVD player nothing works. Anyone have any suggestions.
Eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Posted on Dec 01, 2007
I have a Sansui VRDVD4001 and mysteriously had this same issue - didn't know it was a progressive scan issue until I saw this posting. DVD sound is fine, VCR sound and picture fine, but no DVD picture. Fix the DVD picture by putting your dvd in and pressing play, then press stop (sometimes you actually have to hit stop twice), then click the "progressive" button on the remote. The "P" on the dvd display should disappear and your dvd picture should re-appear.
Posted on Jul 15, 2008
I had same problem from the box. Called and was told to reset unit (hold fast fwd & rewind down and turn on).
Riley
Posted on Dec 15, 2007
Sounds like you have activated the PAL on the system. Press on the N/B on the remote and your problem should be solved.
Posted on Nov 23, 2007
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
What brand and what model is it?
Try using composite cables instead of component cables.
Posted on Nov 17, 2007
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Jan 11, 2008 | Progressive DVHE210 210 DVD Player
Progressive Scan
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Jan 04, 2008 | Zenith XBV442 DVD Player/VCR
PROGRESIVE SCAN
I have the samne problem, hoiwever when I press the menu/setup button it says setup on the display but nothing changes on the tv, it does not have a navigation menu, any suggestions on what to do to remove the progressive scan from my screen
Nov 05, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
How to turn off progressive scan on Allegro Dvd Player
yeah.same here.=[
but it only says that for the dvd mode.
Oct 24, 2007 | Allegro DVD/VCR ABV511
Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Mar 20, 2007 | Samsung DVD-V4600 DVD Player/VCR
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
TruTech TT320 Logo
295 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
