Question about Maytag Neptune MDE5500AY Electric Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Posted on Jul 14, 2009
    Problem Solver:
  • 7 Answers
Usually the squeaking noise that comes from a dryer is the IDLER. Usually if it squeaks or squeals it is worn out.
They are relatively easy to replace and usually not that expensive.
2 Suggested Answers
  • 574 Answers
SOURCE: dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Posted on Aug 31, 2009
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
Dryer is making a god awful squeaky/grinding sound when turned on. It will stop for a bit and then start up again every 4-5 minutes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Amana NDE5805AY Electric Dryer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a loud squeaky noise
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
My dryer is making a very loud squeaky noise. Is is the motor or something else?
Not the motor if it's still working. The noise is coming from the bushing that hold the drum in place.
Apr 05, 2009 | Maytag Dryers
Gas dryer makes loud noise when first started. noise level goes down after running several minutes
heatman101
fghgs
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
862 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
