Question about Toshiba Satellite Notebook Computer (P35S605) PC Notebook
My toshiba satellite p35-s605 shuts itself off
My toshiba satellite p35-s605 has been having problems for a long time. It does this thing where it will just randomly shut off for no reason. I scanned it in case it had a virus, but it didn't. I even sent it away to have it looked at because I thought it might have been the fans underneath overheating, but it wasn't and they formated it, but the problem was still there. I tried buying a new battery and also a new charger, but neither of them help. Now my computer is to the point where when i try to turn it on, it will get only as far as the XP welcome screen and it will turn itself off and the lights on the front go out. My friend said he thought it was the mother board. Is this the case or could there be another reason for it?
  • tasha_vds Jul 14, 2009
    I'll give that a shot, but would something like that cause connection problems? Like...my charger will be plugged in and sometimes it will work and sometimes it wont. Also, the only way i can even run it is if it's plugged into it. It wont even turn on or light up if it's not connected to the ac adapter.
  • Toshiba Master
  • 4,806 Answers
It certainly could be a case of a bad motherboard but i would check the air vents for dust that may have clogged up, even though the fan may appear to be working fine if there is dust built up inside the unit there is nowhere for the hot air to vent, this will in turn cause the laptop to shut down unexpectedly.
Also go into the BIOS and set it to default settings just in case someone has set a shutdown temperature.
Regards.
Posted on Jul 14, 2009
2 Suggested Answers
  • 44 Answers
SOURCE: P35-S605 Left side of the screen flashing
You have a crack in your LCD. You need to replace the LCD.
Posted on Feb 07, 2010
Toshiba Satellite Pro P35-S605 beeps upon power up then crashes and reboots.
Can you get into Safe Mode? I suspect your configuration needs tweeking.
Also I would immediately go into the Bios and make the boot order be CD, HD.. etc. Also make note of any hidden partitions such as H, or K. Those sometimes house a mirror of the factory version of XP... like when it was new.
Good luck
Nov 20, 2012 | Toshiba Satellite P35-S605 Notebook
Icannot access imternetIneed a driver for the modem
If you are using a Windows XP system of even windows 7, the following instructions will help you get your driver problem solved: http://www.computing-tips.net/Solved_Find_Install_Windows_XP_Drivers_Easily
Mar 30, 2011 | Toshiba Satellite P35-S605 Notebook
My laptop keeps shutting donw after a short period of time and the cpu area is hot during this time. any help
Clogged heatsink and fan / copper radiator. You need to remove the CPU cover (if possible) and hoover around the fan area to remove dust and debris. You mat have to take it apart to get to the cooling parts though. IF you chosoe to remove the heatsink to clean thoroughly, remember to apply some CPU grease between the cpu and heatsink.
Jan 12, 2011 | Toshiba Satellite P35-S605 Notebook
Hi since I installed windows 7 in my toshiba satellite P35-S605 pc I haven't been able to use my tv as screen. What do I do? Thanks
You need to configure it as a second display. Connect the tv to the laptop, right-click on the desktop and choose Screen resolution, select the 2, put a resolution supported by your tv and select the Extend option.
Jul 01, 2010 | Toshiba Satellite P35-S605 Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Wanted to find Owners Manual for Toshiba Satellite P35 S605 Laptop
Go to this site and click on the user guide tab:
http://tinyurl.com/nwdvdz
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 10, 2009 | Toshiba Satelitte P35-S605 Notebook PC
What do you do regarding the toshiba satellite powering down
Depending on a few things, this may be a feature or a problem.
Does it seem to shut down within a specific time period?
Does this time period remain constant, and change only if on battery vs. plugged in?
If this is the case then it probably your power management settings.
Check the control panel, and configure them to your preference.
To access the Power Options in the Control Panel in XP:
Start > Control Panel > Power Options
There you will see specific settings regarding monitor, hard disks and standby. Your machine is most likely going into standby, check the time, and select something more appropriate for your needs or disable it all together.
In Vista, you will see a more streamlined set of options. "Always On/Plugged In" "Minimal Power Saving" Etc. would be the best choice
The choice is yours.
Let us know.
Good luck
Apr 16, 2009 | Toshiba Satellite P35-S605 Notebook
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Verticle line in the middle of the monitor.
IT'S THE PROBLEM IN THE DISPLAY PANEL GET IT CHECK THROUGH A SERVICEMAN
Oct 01, 2008 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
389 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
