Question about Whirlpool Dryers
Whirlpool dryer wont start
Not the fuse. does nothing when i hit start button... had a beaded shirt caught in the door but cannot see anything blocking connection.. tool apart everything cleaned out everything nothing looks burnt lint in lmachine doesnt smell burnt... the relay to start may be a little wierd but now i may just be thinking things...
  • 1 more comment
  • tanya_maisch Jul 15, 2009
    i pushes in and light turns off and on there are three wires that go to the relay on the door... my thoughts are that if the relay on door was broken the light wouldnt come on but as i cannot come up with another option im not sure and as i am new to fixing thing ( my father thought it was a mans job...lol) i am not sure how to get the wires out of the plastic to try to connect them and see if it does anything... is there a special tool or i should just yank it hard...btw thanks in advance for any help
  • tanya_maisch Jul 20, 2009
    got a new dryer thanks for the two people who tried to help
  • bobby18rg May 11, 2010
    Did you check the safety switch on the door? The switch must be pushed in for the dryer to work.
  • Whirlpool Master
  • 1,606 Answers
Check the door switch actuator (the piece sticking down that the door actuates when closing . Could have broken off . If there , and you hear a click , then thermal fus (white piece with 2 wires attached ) could be problem . Disconnect power and put the 2 wires togather. Reconnect power and see if dryer starts . I have never had to replace a push-to-start switch .
Posted on Jul 19, 2009
Whirlpool dryers use a plastic thermal fuse mounted on the vent chute on the rear of the dryer (access it with cover removed). In the gas dryer, if the fuse opens it stops ignition. On the electric dryer, it stops the unit from turning on, Test this by by-passing the fuse-stat.
Posted on Feb 15, 2013
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
Estate dryer wont engage
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wont react when hit start button
HI, Sounds like Normal 0 , UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
a fuse. Try this,
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
WHIRLPOOL DRYER WON'T START
It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
Mar 08, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Gold Ultra Care 2 Dryer
check main breakers or fuses
Jan 12, 2008 | Dryers
Dryers Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
