Question about Hayward 1.5 Hp Northstar High Performance Pump
Hi, i also have cloudy water, i have a 1.5 hp pump with a starclear 1200 filter, i think the filter is bypassing as the filters internal seals do not seem to be tight enough...and this is the second element i am on.... do they sell any additional gasketing tomake up for the slack, poor manufacturing of tolerances?
  • 4 Answers
Some times if you have an imblance of salts within your pool you will see this "cloudy water" you are referring to. Make sure that the water is cloudy before entering the filter and not the other way around.
Next, make sure that the current gasket/o-ring that is being used has silicone based grease applied to the gasket/o-ring surface. When you replace the filter and reset the oring and gasket enusre that the proper tightening torque is achieved at each bolt. Make sure that you cross tighten the bolts. Much like replacing a wheel on a car.
Finally, if all of these steps have not helped you then you can make your own gasket by either using "Gasket Paper" or "Liquid Gasket". Advantage to using Gasket Paper is that it is less messy and easier to change out.
With Gasket Paper, make sure that you trace out the previous Gasket on Gasket Paper before installing. I would still recommend using a light cote of Silicone Based Greased around the new gasket before installation.
Posted on Aug 04, 2009
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
How to change water filter on msd2352kew
Instructions on how to change the water filter are found on page 20 of the user manual Here=> MSD2352KEW User Manual
I will be here should you have questions, Thanks Sea Breeze
corner of the fresh food compartment.
1. Remove blue bypass cap and
retain for later use.
end of filter and insert into
filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs
steady. During initial use,
allow about a one- to two-minute delay in water
dispersal to allow internal water tank to fill.
• Additional flushing may be required in some
households where water is of poor quality
Mar 22, 2013 | Maytag Refrigerators
Is my pool pump filtering correctly?
The cloudiness or turbidity of your water indicates a leaking or damaged filter membrane/element. The green color is due to the growth of algae. Are you using the right algaecide? Is the dose right? You have to consult a water treatment specialist to know these.
Aug 06, 2012 | Hayward Pool Products Hayward Pro Series...
How do I backwash my sanddollar pool filter
Shut the pump off, then push down on the backwash (BW) handel turn it clockwise 180 degrees to BW and start pump again. Run pump till water coming from BW pipe runs from cloudy to clear. Shut the pump off and pushing down on the BW handel again turn it 180 degrees to filter and start pump again.
Oct 27, 2010 | Pentair Sand Dollar 19" Filter with 1 Hp...
Pressure on the EC65 is always high
Certainly sounds like a filter problem. Here's a couple of things to try.#1. i don't know how you cleaned the filters but clean them again with a good filter cleaner/degreaser.#2. After a good cleaning, get a bucket large enough to hold the filter fingers in and give them an acid bath. They recommend a 20 to 1 ratio of water to acid (muriatic) but I personally don' think thats strong enough. Use a good amount of acid and let the fingers soak for a good ten or fifteen minutes. (always add acid to water, not water to acid) Rinse and reassemble filter. If that does'nt solve problem, I think it's time to replace filter.
Jun 17, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Where is the water filter located on the Samsung SRS2028CSS
upper right-hand corner of the fresh
food compartment.
2. Remove sealing label from end
of filter and insert into filter head.
closed.
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Pool filter not doing its job
try using a clarifier that you add into the skimmer such as Clearex 500.
The flocculent only makes particles drop to the pool floor, a liquid clarifier actually coates the sand and will filter smaller particles. Also, check the o-rings on the backwash valve. If the o-ring(s) are damaged it may be letting some water bypass the filter.
Sep 06, 2009 | Astral Products Difusser 1/2 Hp - 1 1/2 Hp
I have a sta-rite pump it will prime but will not putout water
COULD IT HAVE A SUCTION LEAK PULLING IN AIR? RUNNING BACKWARDS? BYPASSING INTERNALLY ALL THE TIME? COULD YOUR DISCHARGE HOSE HAVE A RESTRICTION IN IT SLOWING IT DOWN? HOPE THIS HELPS, JODY
Aug 31, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
4.3 oil filter blowing seals
before you put the filter on pour oil into bottle lid and pour on the rubber seal and use your finger to rub oil on seal. it should work
Feb 03, 2009 | 2000 Chevrolet Astro
Hayward 1.5 Hp Northstar High Performance Pump Logo
98 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
