Question about IBM Office Equipment & Supplies
IBM info print 1552 error message 929.00: Service Toner Sensor.
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 300 Answers
SOURCE: infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Posted on Jun 09, 2008
SOURCE: 929 service toner sensor error
well i was having the same problem and what i did was open up the side of the printer. the same side that the toner sensor is on. the sensor consists of three metal parts. i took a screwdriver and pressed them on the outside. i pressed them in and up to ensure that the sensors are connecting. and i have not had that problem since.
Posted on Dec 11, 2008
  • 412 Answers
Error: 929 Toner Sensor
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
Click here to order toner cartridges and other supplies for your printer.
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
Turn off the printer and remove the toner cartridge.
Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
Posted on Mar 09, 2009
rsmith972278
  • 160 Answers
SOURCE: I recently changed the toner cartridge on my IBM
It took me a long while, but I finally found you a free manual. I think ! Check it out and see.
CLICK HERE --> http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this helps,.
RSMITH972278
P.S. IF YOU NEED ANYTHING CONTACT ME
P.P.S. PLEASE DON'T FORGET TO RATE ME
Posted on Oct 15, 2009
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
Will not print gives check tray 1 paper jam on screen
There will usually be something in there, whether it is toner/ink over a sensor, a paperclip/staple, or a tiny scrap of paper.
The trick with this one is patience, methodically strip it down as far as you can, checking as you go for stuck material, and once you have gone as far as you can put it back together nice and slowly, looking for broken connections and loose bits, then try it again.
If there is nothing in there then the printer has something broken and needs looking at by a technician, in this case you should turn to your warrenty.
Please please remember to vote if my solution was helpful to you, and if I did not help then please let me know and I can try further steps to assist you :)
Nov 01, 2010 | IBM Infoprint 1552 Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Feb 08, 2010 | IBM Infoprint 1552 Laser Printer
I recently changed the toner cartridge on my IBM Infoprint 1552. Now I get a thin smudgy line all the way down the right side of printed materials. I know it needs to be cleaned, but I don't have a manual,...
Chances are you have a smudge on your drum roller... (its the shiny metallic tube). Roll it around and see if can see any foreign materials on it, and wipe it off carefully with a lint-free cloth.
Oct 15, 2009 | IBM Infoprint 1552 Laser Printer
Fatal error 21h; and problem printing even without the error
open side cover and there is a plastic, if you raise that plastic piece the ohp sensor should be located under this plastic
second problem, try uninstalling the printer and re install it, should solve this.
Nov 09, 2008 | Konica Minolta magicolor 2300DL Laser...
Infoprint 1120 929 service toner sensor error code
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
929 SENSOR ERROR
It normally means the print cartridge is defective
Mar 24, 2008 | IBM Infoprint 1352 Laser Printer
339 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
