How to put a belt on a hotpoint aquarious.need help please
  • Washing Mach... Master
  • 3,463 Answers
Hi.
Remove top cover and lower rear panel.
Tilt washer forward and get someone to support it for you.
Fit belt round motor pulley first, and slowly feed belt round drum pulley, turning pulley at same time, watch you fingers!!.
It is tight, but is meant to be .
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
Hotpoint Aquaris df62 - the rinse aid reservoir seems to be blocked with crude and won't allow me to fill it up..How do i clean this out?
you cannot clean it out ,the whole dispenser needs to be replaced . you should be able to get the dispenser kinda cheap
Feb 20, 2013 | Dishwashers
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
HOTPOINT AQUARIES WM63 , NO SPIN SPEED- MOTOR WORKS OK ON WASH, BRUSHES LOOK OK.
If the brushes are less than 3 or 4 mm long, then they need replacing.
If still no spin , but washes o/k, then the high speed part of the motor windings could be faulty, which entails replacing the motor.
Thankyou
Jan 19, 2010 | Hotpoint Washing Machines
Hotpoint Aquarious 1200 IE When spinning the drum ocsillates violently and is very noisy.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Tghanks.
Sep 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarious extra wd63 motor mounting broken
Made a new mounting bracket out of a piece of flat bar. Machine has never run so quietly!
Jun 13, 2009 | Washing Machines
Location of element
Hi, Hotpoint FDW60 got a concealled element.
You need to unplug and disconnect the dw, lay it flat on its back and remove the bottom tray (depending on the final letter for your model (FDW60G, FDW60P, FDW60T) you might need to remove the side panels and kickboard to release the bottom tray). Carefull with the floater switch. You should be able to locate the element straight away. Replace it and reverse the process.
Cheers
Feb 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Replacing the belt on a Hotpoint Aquarious Tumble dryer
I cannot find a support site for sears appliances that was helpful but most of them have spring clips that hold the top into place just pry it shightly up and pull it the rest of the way starting from the front. Once the top is opened you can see the motor and belt. You can also see it from the bottom by tiping it up and laying it on the side
Jan 01, 2009 | Hotpoint TDL14 Electric Dryer
Hotpoint Aquarious TDC32 Hi, Can you help me please? The drum on my tumble dryer has stopped turning round. The motor is still working ok, do you think it might be the drum belt? Before it stopped...
ths will be the belt if the motors working then thats the only thing it can be undue the screws at the back of the lid take the lid of if u cant see the belt around the drum its broke if u can just try and pull it up if it comes totally out its broke if not then it has come off the rolllers which r situated at the bottom of the drier u can get to these by taking the bottom cover off at the back BUT ALWAYS SWITCH OFF AT THE POWER AND UN-PLUG THE DRIER love
Mar 09, 2008 | Dryers
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
