Question about Kenmore 53701 Dehumidifier
I have MODEL 580,53701 AND IT WAS DOING JUST GREAT. i WAS HAVEING TO EMPTY IT ABOUT EVERY OTHER DAY. NOW NO WATER AT ALL NO MATER HOW LONG IT RUNS. WHAT GIVES?
  • 3,230 Answers
try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system.
Good Luck!!
Thanks
Posted on Jul 14, 2009
Our daewoo humidifier model dhc-250 date made 02/04 runs but seems like voltage goes up and down if on low or high fan and cont. cleaned all out ran great last year but now runs can hear power click up and...
Quite frankly, from what you described, you may need to have the refrigerant gas in the compressor drained and recharged. As. it sounds like the compressor wants to turn on, but lacks the ability due to low refrigerant or a faulty condenser switch. Either one can be repaired. But, if you don't have the experience to deal with it, it's best left to the pros.
Hope this helped you to troubleshoot and solve the problem.
Jun 21, 2011 | Daewoo DHC250 Dehumidifier
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Our dehumidifier is a Danby model no. ddr301, Normally we would empty the recevoir every day full of water however, at this moment I cannot seem to program. It"s only the heat.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 24, 2011 | Dehumidifiers
I purchased a 45 pint/day dehumidifier model # DD45P last year and it worked great. We needed to empty it almost every day as it was located in our lower level at a lake home. We have just returned to our...
heatman101
Apr 11, 2011 | DeLonghi Dehumidifiers
Unit works fan runs lights turn on but no water in the bucket,
Some units use the condensate water to cool down the condenser coil. This is why no water is present. If water is leaking from the unit or you are still sceptical about this problem, I would call for service.
Mat
Jul 16, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier running but no pulling any water from the room
Check float switch some of the unit have afloat switch hooked to the unit. Next check the condenser coilsThey do get stopped up cat,dog hair and just plain get dirty vaccuum them out and try unit. Rusty
Jun 12, 2009 | Bionaire BDQ24 Quietech Dehumidifier
Kenmore 53701 Dehumidifier Logo
60 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
