Question about Texas Instruments TI-83 Plus Calculator
It will not turn on
I have 10 ti 83 calculators that will not turn on. We already changed the little and big batteries in the back and they just will not turn on
  • Texas Instru... Master
  • 7,993 Answers
The problem may be due to the screen contrast being too low.
You can play with the contrast (increase or decrease).
To change contrast you perform the following manipulations.
1. Turn calculator ON
2. Press [2nd] key, then release it.
3. Press Up arrow, then release it
4. Repeat steps 2, and 3, until contrast is satisfactory.
To decrease contrast do as above, pressing Down arrow in step 3.
Hope it helps lighten up those screens
Posted on Sep 01, 2009
There's something wrong with my TI-83. When I'm typing up an equation it will randomly shut off. And when it's on it will have shown that the RAM was cleared. Now it sometimes takes like 5 presses of the...
Have you tried changing the batteries? I'd try that first thing. From your description, the problem sounds like you have low batteries. The RAM shouldn't clear itself when you turn the calculator on unless you tried to turn it on when the calculator didn't have any juice. The TI-83 has four AAA batteries and one CR1616 battery it uses for memory backup. The CR1616 isn't enough to power the calculator, just enough to keep your calculator from losing its RAM contents while the primary batteries are out. If you try to power the calculator on without primary batteries, the backup fails. However, the TI-8x line is usually pretty good about warning you when the batteries are low by displaying a big warning message when you turn it on about the batteries being low and a recommended change of batteries. It might not, though, so you really can't be sure until you try a fresh set of batteries. Good luck!
Apr 09, 2011 | Texas Instruments TI-83 Plus Calculator
After I changed the batteries, and turned it back on, it said 'I see you'. This is a little creepy, is that normal?
YES. It is normal. LOL.
I've been through the same thing. One time when I replaced the batteries and turned it back on, my TI-83 told me "I know what you did last summer".
Seeing how I think you are just kidding around, I will address this question to those others who may be reading.
The TI-83 has an alpha-numeric keypad. This is a fancy way of saying that you can type letters onto the screen. If you replace the batteries before the batteries die, the calculator will NOT lose any memory. Therefore, this is just a case of someone typing in a predetermined phrase "I see You". Then turning off the calculator, replacing the batteries, and turning it back on.
PEACE.
Mar 12, 2011 | Texas Instruments TI-83 Plus Calculator
I haven't used the calculator in a long time(TI 83 plus) and I put in a new set of batteries. The old ones that were in left some battery acid, but not much. The calculator doesn't want to turn on. It's a...
hi adamsukienni,
Clean the battery damage up real good. Gently scrape to terminals of corrosion. Back in my day we use to put a little bit of coke cola to clean car battery posts to get a good connection. If you could put a little bit of coke on a Q-tip without getting any inside the calculator that would be good. Just let it soak in for about 30 minutes. And gently scrape the bad areas again clean of the corrosion. You have to clean it up to metal so, that when the battery is in it will be metal to metal connection.
If you can download new OS with another Ti83 Plus or, don't want to install the new OS goto Procedure 1.
Be ready to install the new ti 83 OS v.1.19. So, setup your computer with Ti Connect software and, have the new OS v.1.19 download ready and, in "My Documents \ My TI Data \ Downloads." If you need additional instructions on how to connect the computer to the calculator you can read my instructions at another posting I did. You can go to that posting by clicking, "Connection Instructions," under this paragraph. Just remember the OS was for a Ti 84 Plus and, your's is a Ti 83 Plus so, don't download the OS from the other posting. I'll give you a link below this paragraph to download the correct Ti 83 Plus OS v1.19 for your calculator here at your posting. Just follow the other posting to where I say, "You can also go back and, download the Ti 84 Plus guidebook too, if needed." After that statement the computer and, calculator get connected with the cable and, your not ready for that process, yet! When you come back to this posting and you have downloaded the new OS to the proper folder goto Procedure 1.
Additional computer to calculator connection instructions click, "Connection Instructions."
Ti 83 Plus OS v.1.19 download click, "Ti 83 Plus OS v.1.19". Save this download to "My Documents \ My TI Data \ Downloads".
Procedure 1.
Take all the batteries out for 10 minutes, including the very small one that you have to use a small philips screw driver to get it out. Watch out for the spring under the small battery, it might pop out. Replace all the batteries after 10 minutes with new ones, including buying a new small battery. The small one might cost about $5. I know it is expensive but, this might work.
A battery reset procedure should bring your Ti 83 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
If your Ti 83 Plus turns on when you put the batteries back in you do not have to re-install the OS. I just think it is better since, your OS might be corrupt.
The process below should reset your calculator.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done. Once again, if your calculator turns on after this procedure you do not have to re-install the new OS. You can quit these procedures now with a perfectly good calculator.
Please be prepared to re-install the calculator's OS, if you run through this process.
2). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Connect to other Ti 83 Plus and, install OS from that calculator. Or, follow the instructions, I gave at the other posting "Connection Instructions" to reinstall the calculator operating system and, connect the computer and, calculator. You can start where, I say, "Link your computer and, Ti 84 Plus (Your's is a Ti 83 Plus) with the proper cable (USB or Black Link). Upon completion your Ti 83 Plus will be ready to use and, the new OS installed.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
How do i turn on my TI-83 when i already put batteries inside? at first the numbers would fade away but now it dosent want to even turn on.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 18, 2010 | Texas Instruments TI-83 Plus Calculator
The calculator will not turn on a TI 83 plus, batteries changed
You say you changed the batteries. Did you also change the back up battery? It's located in a little door with a screw right above the AAA batteries.
My students have come to me many times and have said that their calculator will not turn on. Most times it is that the contrast on the screen has been turned down and the calculator is turning on but the screen is too dim to see that it's on.
To check your contrast, turn the calculator on, press the 2nd key and the up arrow. This is how you darken the screen. You lighten the screen the same way but you use the down arrow instead.
Aug 23, 2009 | Texas Instruments TI-84 Plus Silver...
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/ti-cares@ti.com if you need specifics on getting the calc to take an OS upload given the state it's in."
Feb 24, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 countdown
Pressing 2nd then the up or down arrows is how you change the contrast on the TI-83. All you need to do is press the 2nd key then hold the down arrow to get your screen back. The countdown that you saw was just the value the calculator assigns to the contrast. It goes from 0-10.
Hope that helps!
Jan 18, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Ti-83 plus
Aug 14, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
318 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
