Question about Maytag Atlantis MAV6000 Top Load Washer
Roaring washer This washer was working ok and recently has started to make  a LOT of noise when spinning. Can you help me locate the problem? I had the front off and the tub spins a little off. There is a yellow material under the transmission. Is this a bearing?
  • 90 Answers
Re: Roaring washer
This is probably a part of the tank water seal. There is a bearing in there also. Does it leak water from that area? Usually the seal goes bad and it starts to drip water down into the bearing below, which starts to rust and then starts to make noise. If you can locate the bearing, you might try dripping a small amount of oil into it to see if it changes the sound any.
Posted on Feb 03, 2008
0 characters
3 Points
Maytag quiet series 100 noise during washing
Roaring noise must also come during the spin cycle I seems your bearing and or drive belt/gear is causing you this noise. To fix this, you would need to completely disassemble the washer and inspect the bearing and or drive box that activates the turning motion. It is a large job.
Dec 02, 2013 | Maytag Washing Machines
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
May 07, 2010 | Washing Machines
My washer has started making a loud roaring noise when it is in spin mode.
Apr 22, 2010 | Kenmore 44102 Front Load Washer
My washer will wash clothes and it drained, but will not spin makes a loud roaring noise what is wrong?
OK, that roaring is coming from a damaged direct drive assembly. the gear box is damaged. you will need to replace asap.
Gear case housing kit with main drive gear will run you about a $190.00
Jun 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
Roaring noise during spin cycle
The roaring noise is from the drum bearing and it will only get worse with time until it fails completely. You will need to replace the rear tub assembly which is about $300 for the part. The rear tub assembly part number is 285984. It will take about 2 hours in labor.
Make sure you are using HE (high efficiency) detergent and only about 2 tablespoons per load.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Mar 08, 2009 | Kenmore 44102 Front Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Duet washer has started to make much more noise in the high speed spin mode, is this normal or is it a service issue?
A loud, roaring noise in high spin speed usually indicates the tub bearing is failing. A large job best left to the professionals.
Jul 04, 2008 | Whirlpool Washing Machines
Is this the bearing
The yellow condition usually means the transmission has a leak or crack in it. This fluid could be causing the bearing to make noise or it could actually be the transmission doing it. Also, sometimes that yellowish stuff could be coming from the bearing getting water in it from a leak somewhere. Check everything really good for leaks. Understand though, unless you have two special tools, do not attempt to do this job yourself. You need a spring removal tool to remove the springs, and a special brake removal ool for the bottom brake. Be sure you dont remove that brake assembly without this tool, the plate will come off with a huge amount of force. Let me know if you need further help or information. Jim
Nov 19, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
