Question about Kenmore 74822 / 74824 Top Freezer Refrigerator
Water leaking on the floor from freezer side.
Water leaks from refrigerator from the freezer side onto the floor. I have to use a hair dryer to break up the ice formation on the bottom of the freezer and remove the ice to keep the problem from occurring. Lasts about 2 days and then I have to do it again.
Kenmore Coldspot model 106.56666500
    Top Expert:
  • Kenmore Master
  • 49,942 Answers
Check for a clogged drain inside bottom rear.
Posted on Dec 24, 2017
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
aborcass
  • 2651 Answers
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: kenmore refrigerator model 106, 2doors, ice forms
I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
Posted on Mar 02, 2009
dealt_soul
  • 296 Answers
SOURCE: water leaking to floor on freezer side
Check all water lines and water selonoid.
Posted on Mar 16, 2009
Ice forming on bottom of freezer with water leaking out from under
I'm guessing the drain from the freezer defrost pan (below the freezer coil) is clogged and overflowing into the bottom of the box. You'll have to turn off an defrost the freezer, then remove the sheet metal on the back to expose the coil. Try pouring some water into the drain pan and if it backs up, use a fine wire like a sewer snake to clean it out.
Feb 28, 2018 | Maytag MBF2256H Bottom Freezer...
I have a Maytag side by side and water is leaking on the floor and I have a big build of ice on the bottom of the freezer. Can you tell me how to fix it?
Unplug the refrigerator.
Remove the food and shelves from the freezer side.
Carefully break up and dispose of the visible ice. There is a drain pan on the lower rear of the freezer. Defrost the ice in this pan with a hair dryer.
Once the ice is out of the pan the drain hole that goes through the bottom of the pan must also be defrosted.
After the drain hole is defrosted pour a mixture of 1/4 cup bleach and 1 and 3/4 cups hot water through the drain hole.
Jan 17, 2010 | Refrigerators
Water runs down back of freezer side and fills small tray on bottom of freezer side then refreezes and over flows onto floor past door seal freezer side also makes a surgeing sound at times
The defrost drain hole in the small tray is frozen over. Turn off the refrigerator. Remove the shelves and bins. Carefully break up the visible ice and dispose of it.
Use a hair dryer to defrost the drain hole. It will be a slow process. Be patient.
Jan 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
Freezer side of a side by side water in the bottom
the drain is clogged.take a hair dryer and un thaw the drain
Dec 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water from freezer pools at the bottom
The drain line for the evaporator is frozen shut. You have to thaw the drain line that is located behind the rear wall in the freezer side. It is at the very bottom and will require a hair dryer or lots of hot water.
Aug 24, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Aug 09, 2009 | Maytag MSD2454G Side by Side Refrigerator
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Water is leaking from the freezer to thge floor. I is a side by side Maytag refrigerator
I had a simular problem - it is EASY to fix once you know what it is. "They" don't tell you that you should clean out the drain once a year..."they" would rather you call a repair man. Empty out the freezer side and remove the bottom panel inside the freezer. If you don't know how to do this google your fridge type and model number and you should be able to find directions to do so. In the very bottom is a drain that can get clogged with ice. Using a hair dryer and hot/warm water melt and gently break away all the ice. Poor hot/warm water over it till completely thawed out. What is supposed to happen with this drain is moisture is supposed to go to a pan under the fridge and evaporate. When it is clogged the water spills out onto the floor. If I can do this anyone can. I was about 50 years old and a woman when I first did this.
Jun 14, 2009 | Maytag MSD2656G Side by Side Refrigerator
Model number f45zr24jw type 7 water filling up at bottem of freezer looks like it is comming from vent at bottom of freezer back wall filles up leaks out onto floor were is water comming from.
water is coming from the evaporator coil durring the defrost cycle and it must drain down into the small hose in the pan where the ice is , turn the unit off to defrost with a hair dryer of you can wait it out , after defrosting the ice puddle , pour a cup of bleach in it and snake it out with a stiff wire or similar. this should clear your clogged primary evaporator drain and stop the water leak.
Phil
Jun 09, 2009 | Frigidaire FRS6R5EMB Side by Side...
Kenmore 74822 / 74824 Top Freezer Refrigerator Logo
202 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
