Question about Xerox Phaser 8200 Laser Printer
I get an error message that says "Printer Error - Contact Service: Report Fault: 15.004.45.1758" Whats does it mean and how can I fix it? Thanks
    President:
  • 2,072 Answers
That means the 2 halogen lamps that serve as the drum heater have gone out. Either one or both have blown.
They simply are 2, ,, 150 watt halogen lamps that you can replace, Takes about an hour to do, I can send you instructions if you want.
E-mail me ,,, rak458@aol.com
Posted on Jul 15, 2009
Fixing unit error. Turn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
Apr 16, 2011 | Canon LASER SHOT LBP-2900 Printer
Says: fault error:116-325 whats this mean pls?
fault error:116 325 A failure of the Controller Fan has been detected. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
Hope this helps. Thanks
Mar 06, 2011 | Office Equipment & Supplies
Have a 2004 GTO with the following error: Fuel Guage Error - Contact Dealer Service Error - Contact Dealer Air Bag Fault - Contact Dealer Any idea how to fix this?
If these are false readings (which I doubt) you can try resetting the system to restore all factory default settings. You need to have the system set in customisation mode to do this.
Check your vehicle handbook which explains the steps to do this.
Once reset drive the car and check the warnings.. If they remain (and they probably will) you will need to take the car to the dealer to diagnose and rectify the problem.
Your handbook explains what each of the warnings means and the air bag fault warning should not be ignored. "Service error" means there is a fault with the instrument panel and Fuel Gauge Error means there is a fault with the fuel level measurement system
Oct 20, 2009 | 2004 Pontiac GTO
I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
May 21, 2009 | HP DesignJet 500ps InkJet Printer
"Print Error-Contact Service; Report Fault 7-401"??
Reset the Tray 2 feed counter within Service Diagnostics as follows:
1. Enter Service Diagnostics (back arrow botton with the "i" button soon as you turn it on) and scroll to NVRAM Access and press OK
2. Scroll to Reset CRU Life Counters and press OK. The display will show the status of all CRUs. Press OK until the Reset Counters menu is displayed.
3. in the Reset Counters menu select Yes and press OK.
4. Scroll to Tray 2 and press OK.
5. Exit diagnostics.
That's what worked for me I called a company called Iteminc they gave me the instructions and they told me to :Replace the tray 2 pick, feed and separate rollers before it starts jamming soon. www.iteminc.com is their website good luck give them a call if it does not work.
Mar 11, 2009 | Xerox Phaser 7750DN Laser Printer
Printer not working
That is a drum warm up fault. There are 2, 150 watt halogen lamps in the drum heater that blow.
If you want to replace them let me know, I will sent you the directions. I can pretty much say 100 percent that is the problem.
Feb 16, 2009 | Xerox Phaser 8200 Laser Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Error code 11,009,46:1444 on Xerox Phaser 8500
A fault code search on Xerox's website says this is an electronics module interface fault--just doesn't say how to fix it!!
Oct 03, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8200 Laser Printer Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
