Question about Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System
Garage door beeps, it flashes couple times. now the door wont open at all
It makes noise like its trying to open but wont
2 Suggested Answers
swolfinor
  • 504 Answers
SOURCE: I have a chamberlain whisper drive garage door
SOUNDS LIKE THE UP LIMIT IS EITHER OUT OF ADJUSTMENT OR NOT WORKING.
TURN IT ABOUT THREE TURNS COUNTER CLOCKWISE. THIS SHOULD BE ENOUGH TO MAKE IT NOT OPEN ALL THE WAY. THEN ADJUST IT 1/2 TURN AT A TIME THE OTHER WAY UNTIL IT GETS CLOSE THEN SMALLER ADJUSTMENTS TILL YOU ARE HAPPY WITH WHERE IT STOPS.
HOPE THIS HELPS
Posted on Nov 11, 2010
Why is my garage door opener beeping?
Hello, Debbie -
I hope you have the user manual for your garage door opener so you can check it to find out what the beeping sound means. If you don't have the manual, you can add the name of the garage door opener manufacturer to your question by using the Edit feature, so that I or someone else can look up information specific to that particular make of garage door opener.
Many instructions I have found for a variety of makes of garage door openers state that the beeping can mean the back up battery for the garage door opener needs replacing. See the information here:
https://www.garagedoorrepairco.com/garage-door-blog/garage-door-opener-beeping-replace-backup-battery
Dec 26, 2017 | Building Materials
My craftsman garage door opener is beeping (2 hours). How can I stop it
Our garage door opener has a safety beam across the floor which prevents the door from closing on objects which are sitting there. This safety feature also makes an annoying beeping sound each time the beam is crossed. This tutorial will show you how to disable the beep, but still keep beam functional. https://www.youtube.com/watch?v=Cn_vGe_7_x4
Jul 14, 2016 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
Keypad opens the garage but wont close it
If when you try to close the door the main light flashes 10 times you have a door sensor problem. Make sure they are pointed at one another.
Aug 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door opens bot wont close i dont have a wireing chart
If when you try to close the door the main light flashes 10 times and the door reverses to the open position you have a sensor problem. Make sure the small light on each sensor is on and not flickering. Tweak them a bit to see if you can get the lights on. If not you have a sensor that has failed.
Mar 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Having problems with my chamberlain 3255. would
If the main light is flashing 10 times it is a door sensor problem. Make sure they are pointed at one another and neither of the lights is flickering.
Jan 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener intermittently not closing
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System Logo
129 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
