Question about BMW 2013 X5 xDrive35i
2013 BMW X5 replaced the spark plugs coils still have the p0301 p0306 codes
Replaced the spark plugs coils still have the p0301 p0306 codes, and i checked the spark plug and it is wet on cylinder 1
    Top Expert:
  • BMW Master
  • 9,098 Answers
Trouble shooting a misfire, Code P0300, P0301 ... - YouTube
? 23:39
https://www.youtube.com/watch?v=G_grIaTgdRI
Oct 26, 2013 - Uploaded by Robert DIY
Trouble shooting a misfire, Code P0300, P0301, P0302, P0303, P0304, P0305, ... How to Diagnose Codes P0301 - P0310 - Cylinder Misfires ...
Diagnose and Repair Misfire Diagnostic Codes P0301 ...
? 9:22
https://www.youtube.com/watch?v=yK7v11ASVgI
May 6, 2014 - Uploaded by JamieJones TheCarMan
Diagnose and Repair Misfire Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A Hyundai ..... P0303 Honda cylinder 3 misfire detected code - Change spark plug - ELM327 OBDII reader with Torque - Duration: ...
? 15:59
https://www.youtube.com/watch?v=Sg7iFytxfzQ
Feb 16, 2014 - Uploaded by Robert DIY
Misfire Trouble Shooting: 30 to 60 minutes ($50 / $75 / $120) If your car is ... Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A ...
Posted on Dec 08, 2015
Testimonial: "p0301, p0306, i replaced the spark plugs and coils , still have the same code , the car has only 29k miles,"
  • Claude Kayser
    Claude Kayser Dec 08, 2015
    It should be the dealer's problem, not yours.
Mercury grand marquis p0351 p0301 p0305 p0306 codes
po301,305 and 306 codes are cylinder misfire codes and the most common problems for them codes are bad coil packs on them engines.
I would suggest pulling them coil packs and inspecting them very closely for any signs of cracks, build up on the metals and inspect the boots for any signs of white tracking! White tracking is a sign that the boots are failing and allowing fire/spark to jump.
Anytime I replace the spark plugs, I always replace the boots! They are very inexpensive and they too fail often!
Hope this helps.
Dec 23, 2017 | Mercury Cars & Trucks
Causes cylinder misfire
Most common cause is an old spark plug that burnt out the coil. Spark plugs should be replaced every 100,000 miles. If the plugs are old replace the spark plugs and swap the coil with cylinder 6. If the code jumps to cylinder 6 you know you have a bad coil.
Apr 03, 2014 | 2002 BMW X5
Making noise
check the coil if coil is ok spark plug if there are ok may damage in emission valve or injectors code relate it to the problems are p0300 p0301 p0302 p0303 p0304 p0305 p0306 p0307 p0308
Apr 01, 2014 | Chevrolet TrailBlazer Cars & Trucks
My car is cutting off every time im going under 1000rpm. mercury sable 2002. codes were p0301 p0302 and p0316 until i changed crank sensor and spark plugs now it says p0316 p0305 p0306.. whats going on?...
Hi
P0305 is misfire in cylinder #5.
P0306 is misfire in cylinder#6.
P0316 is misfire on start up.
Have the plugs on those 2 cylinders, and the 2 fuel injectors checked, also check for spark from the coil on those 2 plug wires.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 05, 2011 | 2002 Mercury Sable
I have a 2006 325I with a P0301 error code in addition to P1553 what is the most likely reason
p0301 is a misfire problem, stands for misfire cylinder 1.
it may caused by Faulty spark plug 1; Faulty ignition coil 1; Ignition coil 1 harness is open or shorted; Ignition coil 1 poor electrical connection; Clogged or faulty fuel injector 1; Injector 1 harness is open or shorted; Injector 1 poor electrical connection; Improper spark plug 1; Insufficient cylinder 1 compression; Incorrect fuel pressure; Intake air leak
greetings
Apr 03, 2011 | 2006 BMW 3 Series
We have a 03 Passat GLX 4Motion, we have replaced spark plugs with NGK V Power Resistor, replaced spark plug wires with BWD Wire Set, and replace the coil with an after market don't remember the brand. We...
p0301 p0302 p0304 p0306 these are all misfire codes im gonna put his in simple words for you is the vehicle running good if it is have the codes removed there stored in the computers memory a parts store has a ob2 scan gun they can erase codes have you tried to have them erased now if the light comes right back see what codes its reading now i looked up all the codes there all refering to the work that was done on your car im not saying the work was done wrong but unless you reset the codes now if they come back the p0351 and p0352 has to do with the ignition coil but i promise you this if your car isnt missing with all theses codes then all that has to be done is erase codes get back with me tell me how it turns out some parts are not compatable with foreign cars
Dec 11, 2010 | 2003 Volkswagen Passat
I got several error codes on my 07 Toyota Avalon, codes P0352,P0300 and P0301-P0306. Does any one one know what could be causing it or how to repair it.
p0352
Ignition coil B primary or secondary circuit malfunction
p0300
Random/multiple cylinder misfire detected
p03001
cylinder no.1 misfire detected
p0306
cylinder no.6 misfire detected
check you coils and spark plugs
make sure they are in good shape. check you spark plug wires also.
Aug 26, 2010 | 2007 Toyota Avalon
03 windstar misses and sputters when it rains,eng lite flashes then stays off 4 a while.then goes off. when dry out it runs great.is it the coil pack
Could possibly be the coil pack has a crack in it, could also be plug wires have cracks in them as well, sounds like time for a tune up. Recommend replacing plugs and wires, and if that doesn't solve the issue then spring for the coil pack. Scanning the computer will tell you what code you have to help point you in the right direction as well. If you have any p0300-p0306 codes those are all misfire codes.p0300 is random multiple misfire, p0301-p0306 are individual cylinder misfires.
Mar 18, 2010 | 2003 Ford Windstar
BMW 2013 X5 xDrive35i Logo
534 people viewed this question
Top BMW Heating & Cooling Experts
Roger
Tom Chichester
Gil Shultz
Are you a BMW Heating and Cooling Expert? Answer questions, earn points and help others
