Question about Acer X193W LCD Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
  • 202 Answers
Does the diosplay show the correct drivers on the monitor and display adapter in device manager? try reloading the drivers for both.most oses wont allow changing of an unknown monitor or display adapter
Posted on Jul 14, 2009
    President:
  • 1,383 Answers
Check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
Feb 22, 2011 | Acer X193W LCD Monitor
I go to screen resolution but the thing is the resolution is greyed out. please help Acer X193w
You need to install the latest drivers for your graphics card, so your computer can run at a higher resolution.
Nvidia Graphics Driver for Nvidia made Graphics Card.
AMD Graphics Driver for AMD Radeon made Graphics Card.
Select your Graphics Card model and Operating System.
Download and install.
Note: Only use the drivers provided for your make and model of graphics card!!!
Thanking you
damnor01
Feb 02, 2011 | Acer X193W LCD Monitor
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
What is the recomended resolution display setting for my Acer X193w monitor
A computer monitor is made of pixels (short for "picture element").
Monitor resolution is measured in pixels, width by height. 640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, an aspect ratio of 4:3. With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), all aspect ratios are the same.
Hope this initial information helps. Let me hear from you again for any clarifications.
Thank you for using fixya.com
Feb 23, 2010 | Acer X193W LCD Monitor
JERKY, SPASMODIC VISUAL STREAMING
kindly check ur graphics card. if ur grphics card is not powerful enough, then reducing the resolution of your monitor will solve ur problem
Feb 17, 2010 | Acer X193W LCD Monitor
What should my screen resolution be
The maximum resolution for the Acer X193W LCD Monitor is 1440 x 90, which is a really good resolution range. It will depend also on what kind of graphics/video card and motherboard your computer has which can help determine if you can use the Acer at that maximum resolution.
Jan 26, 2010 | Acer X193W LCD Monitor
The resolution comes and goes...
For that when you power up the computer press F8 key then enter in safe mode.
Then uninstall graphic driver then start it in normal mode then install graphic driver again then it wroks fine.
Let me know if you need more assistance.
Thanks.
Oct 05, 2009 | Acer X193W LCD Monitor
Acer x193w on win xp woulnt go above 800x600 resolution
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within it display range and 1440x900 is definitely within that range.
Dec 16, 2008 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
719 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
