Question about Ariens 34 In. Zoom Series Riding Mower
I just installed mulch kit on my Ariens 34" zero turn mower. It engages and cuts fine, however there is a loud noise when I disengage the PTO. Don't know if its the belt, pulley or blades
I'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
Posted on Sep 14, 2009
Ariens ZTR 1540 zero turn riding mower trembles real bad and chokes out when PTO is engaged
look at blades for bent or damage--check pulleys ,belts and mandrels ,bearings for binding or loose bolts
Aug 11, 2016 | Ariens Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
Turn zero
sorry but i would talk to the shop about that.
Jul 30, 2013 | Ariens Zoom 42 In 165 HP Briggs Stratton...
PTO WILL NOT CUT ON
I would check that you have a 12 volt supply down at the clutch when the pto switch is pulled out, if not you need to investigate the wireing and or micro switches,
Mar 13, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Cant find the PTO deck belt for a Ariens Sport Zoom Model 915031-1232. Ita a zero turn mower. The manual calls for belt # 07242700 cant find it anywhere! Help.....
I own this model as well. The manufacturer issued a "cutting improvement kit" for this model number. The belt number has changed as well. The number you now need is # 07242200
I am in the process of ordering one for mine right now. Good luck!
Apr 14, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ariens ezr1742 mower blades do not engage....noticed after went over a stump.
The common cause of this problem is that one of the safty switches has come dis-connected or has failed since most every newer mower has a electric clutch controlling the mower deck PTO there are safties bilt in under the seat and in other locations to make sure everything is ok before the blades engage, easiest way to test this is to run a jumper from the positive post of the battery to the input wire on the electric clutch assembly making sure all other wires ade dis-connected from the clutch and see if the blades engage if so then usint a continuity tester check all the wires and switches to this item to check for a faulty switch or broken wire. Thanks Don
Nov 09, 2009 | Ariens 34 In. Zoom Series Riding Mower
Arien 34- Blades won't engage
This mower has an electric PTO on it. I had a Scag and the electric PTO clutch went out on it. Not the cheapest things to change but easy to do yourself with some basic tools. Also, before running out and getting a new one, check the wires to it and to the engage/disengage switch. You may have a bad connection.
Oct 12, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
536 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
