Question about Audiovox D1708 Portable DVD Player
No disk when i put the dvd in the message no disk comes up short of throwing it away what if anything can i do
  • 4 more comments
  • Anonymous Nov 19, 2007
    no disk
  • Anonymous Nov 26, 2007
    there is power but when i place the disc it can't be read can't watch the mulan pic i waited for it but it doesn't play what is the prob
  • Anonymous Nov 29, 2007
    This brand is recognized by low quality and poor customer service practices. My unit is just 5 months old and has the no disc problem.
  • Anonymous Jun 03, 2008
    says loading...then no disc
  • tiacapo Jul 22, 2008
    When DVD is put into portable DVD player and top is shut DVD is not spinning inside. Error message states no DVD
  • momof2js Aug 02, 2008
    its 2 months old and same problems. Ugh!!
I have this same problem. I tried using a disc cleaner & that didn't help. The wierd thing is my unit will play CD's, but not any DVD's!
Posted on Dec 11, 2007
MVD2050 will not turn on. We have a DVD stuck in it. We turned the power off and back on after 60 minutes but nothing happens.
Hello K4, hi you can manually get the disk out, but you need to remove the cover. As for the power thing, you have a power supply problem, would you like to service it yourself or call a technician, If you will service it yourself, this are the things you should check:
  1. fuse
  2. open wirings
  3. shorted or over heating rectifier diodes and voltage regulator
  4. bulging filter capacitors
  5. Switching regulator IC, check for the output pulse using a scope.
  6. replace the bad parts, then test.
Apr 28, 2010 | Memorex MVD2050-BLK DVD Player
Getting a rec error message whilst trying to eject mini disc
i have just solved the problem get a small flat head screw driver and whilst ejecting put it into the hole where the mini disk goes. now when i say gentle i mean gentle GENTLY feel for the edge of the mini disk you will find it. When you know you have found it very gently and slowly push the mini disk up and down and the disk will pop out you wont damage anything as long as you are slow and gentle. If it doesnt happen first time dont worry it will with patience but dont be heavy with it. The problem is the disk and not the player. you have a corrupt disk which is quiet common. Just throw the disk away. Turn the machine off for 10 seconds and turn back on put another disk in that your not bothered about and you will see that it shoudl play etc try recording onto that disk and you shoudl see that the player is working fine
hope this helps
Oct 08, 2009 | Tascam MD-350 Advanced MiniDisc Recorder
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Unknown disk, please check disk again.
did you finalize your dvd? also, the following describes the answer to alot of dvd error problems.
Jun 19, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Won't boot. Power light on, No Video Signal message
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Dec 12, 2008 | Gateway Media Center 610XL PC Desktop
Cyberhome dvd player
ok if you already have it fixed great but if not here is a solution if the other ones that were told didnt work... My sister had the same dvd player it wouldnt load any of the dvds. so she gave it to me. If you dont want to risk what im going to tell you than well u can pay 200 dollars or somthing to get it fixed. Take the top part of the dvd player off. you then take the little disk cover that holds the disk on the player off. if you can push the laser as close as you can to the thing that spins the disk. now if that doesnt work clean the lens by taking prokide or rubbing alchol with a q tip and just rub the lens lightly. it should clean that off. put everything back together and then try it. if it still doesnt work the mother board in it could be fried. if that is the case than well u can get it fixed for no telling how much. if you dont wont to pay anything than throw it away. Hope this helps!
Nov 01, 2008 | Cyberhome CH-DVD 300 DVD Player
Record to disk
I was having the same problem and tried many different types of DVD-R (16x, 8x, even 4x thining speed might be the problem) finally went to the web page and downloaded the updated program. When I put that download into the disk drive the machine read it and the problem went away. Had not been able to use high speed before that either but it worked after the updated program was in it.
Jun 19, 2008 | Panasonic DMR-E85H DVD Recorder
Disk not spinning starts and stops does not do even one turn
its the firmware you need to upgrate it to play copied disks
Nov 15, 2007 | Audio Players & Recorders
Error message
i think your problem is that your lens( laser lens) that reads the disk is dirty. Try this get q-tip and put just little rubbing alcohol and clean the lens.
May 30, 2007 | Toshiba SD-K620 DVD Player
Audiovox D1708 Portable DVD Player Logo
85 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
