Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV goes off after a few minutes
The TV will only stay on for a few minutes and then the power light goes off and TV turns off. Wont come back on for a few minutes
  • 8 Answers
SOURCE: TV will not power up
LoL!!! I don't know why but all RCA's have Flyback Transformer problems! I have one to here is the part number 259296 if you look around you can buy it for about 15.00 if you know how to solder you can do it your self and save big time! Hey I'm doing it! I don't see paying $500.00 to fix it you could buy a new one. And they are just ripping people off because the parts aren't really that high to fix the flashing light problem. And the part is never on back order so your getting screwed they are probably wanting you to finally say just throw it away. And than they'll fix it for $15.00 and sell it for $600.00 Anyways for the people that are having the same problem go here to buy the Flyback Transformer for the D52W20 http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=c5d90cbb7ae2d4c1449ea48542eef46a&keywords=259296&x=4&y=14
Also here is another website if you have access to junk TV's and want to know what other RCA Flyback Transformer will work. The price on this site is higher for there's though
http://www.partstore.com/Part/Thomson/RCA/D52W20/Thomson/RCA/259296/New.aspx
Posted on Dec 10, 2007
  • 579 Answers
SOURCE: power light
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price (less than $200) and install it in the old lamp yourself. really easy.
Posted on Jan 03, 2008
SOURCE: RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Posted on Jan 18, 2008
ladywinn
  • 5138 Answers
SOURCE: POWER WONT STAY ON
You have bad Capacitors cp150 2200uf 16v, cp111 330uf 35v cp114 220uf 35v this is common with these sets they are on your deflection board green with gold writing 2200uf etc. Look at capacitor cp150 if it has a bubble look on top it is bad so replace all 3 caps.
Posted on Oct 18, 2008
walesarumi
  • 6993 Answers
SOURCE: RCA 52" proj. tv will
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Dec 03, 2010
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung tv wont turn on and lights stay flashing in front
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 04, 2013 | Samsung Televison & Video
I'm having trouble turning on my TV. when I turn it on the green light comes on then goes off a couple of times then goes off. I have to wait a few minutes then try it again a few times before it comes on...
hello my name is rico, you have cold solder in your power supply, you need to open the back of your tv and your tv boards upside down, so you can look cold solder and resolder it, before you damage your tv more. if you need more help, feel free to call me at anytime. 602-810-7149
Jan 07, 2011 | RCA HD52W56 52" Rear Projection HDTV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Philips TV 27PT543S37A
ctgarden girl, my set does the EXACT same thing! I too wondered if a cold room was an issue. The set is only 4 years old, and I didn't have this problem in my old place where the room was a lot warmer.
Can someone please help?!?!?!?
Jul 08, 2008 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
316 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
