My air condition stopped working, that is it blows in the house but the outside fan is not blowing. also on the back of the outside fan motor it was quite hot to the touch, i thought that was hot since it had not been running and i heard i little buzzing sound coming from the fan. its going to be 107 today , please help
    Scholar:
  • 91 Answers
The motor gets hot from over amping for various reasons. Nine times out of ten the fan motor needs to be replaced. This really isn;t something that most people can do without proper training. The way it's done on the outside chance that you have the mechanical expertise is, you shut the electric off to the A\C, with a 5/16s driver unscrew the sheetmetal screws at the top of the unit and gently lift the lid and unbolt the four bolts holding the motor turn over lid, pull the electric leads of, making notation where each goes, back the retainer screw off fan blade and remove blade. Unscrew belly band pull out motor. Take this motor to the parts supplier to match exactly the right motor. (All of this is probably academic because almost all supply houses do not sell to the public, it's too dangerous) If you get the motor just reverse everything you did to take the other one out. The best route is to spend a couple hundred dollars and pay a Tech to do it right, It's more involved than an electric or plumbing fix. One other thing to get you by. Get a square box fan and fix it to the top, expelling the air upwards, turn on high and turn on unit, This usually works til a Tech arrives. It may not be as good as normal but it will cool to some degree. Good Luck
Posted on Jul 14, 2009
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
Why is my heil Air exchanger fan not blowing
Sounds like you may have a bade blower motor.
Aug 17, 2014 | Heating & Cooling
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Unit outside isnt working
Replace the run capacitor, too.
Jun 23, 2009 | Goodman CKL24AR24 Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
No air is coming through air ducts
filter could be stopped up on return air or coil frozen due to low charge
May 16, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
