Question about Canon MX300 Office All-In-One Printer
Someone can help me?
Error u 162 col
    President:
  • 2,306 Answers
U 162 means that the remaining ink is unknown. You have to hold the stop/reset button for 5 seconds or more and the error will be reset, but it won't tell you when the ink runs out.
Posted on Jul 14, 2009
We just fixed the EGR valve and now 3 weeks later the P2097 error code was detected.
Not sure of your vehicle but it is not likely that it's part of the EGR valve although you need to make sure the gasket for the EGR valve isn't leaking because leaking exhaust will set this code. Does your vehicle have a EGR solenoid/transducer. The reason I ask is because in Chrysler products the EGR valve and transducers are calibrated together and this may be causing the EGR to open to much and exhaust will leak. I serious don't that it has anything to do with the EGR valve you just replaced however. I think you just have another problem. That's my opinion anyway. The possible causes of the code is: • Leakage exhaust gas • Rear HO2S malfunction • IAT sensor malfunction • ECT sensor malfunction • Front HO2S malfunction • Excessive fuel line pressure • Fuel pump unit malfunction • Purge solenoid valve malfunction • Insufficient engine compression • PCM malfunction Find out about the transducer and then go from there like O2 sensors as well as the other possible causes. I wish I could be more help and I hope this helped a little anyhow. Good luck.
Apr 25, 2011 | Chrysler Town & Country Cars & Trucks
Como quitar el error sc 819 de una ricoh 3025
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
I have a savin 8025e and it is giving me an error code sc542 what is the fix for this
SC542 = Fuser warm-up error.
Possible causes are:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective fusing lamp
• Defective power supply unit
You can try resetting the code using this sequence...
Press the Yellow button, 1,0,7, Press & hold red stop button until machine beeps and the display changes. Then turn the copier off and back on.
Hopefully the machine will now come to ready. OIf not the likely cause is either ther thermal fuse or heater lamp.
Hope this helps
Feb 03, 2011 | Ricoh Aficio MP 161 Black and White Copier
Paper thickness error
From page 88 of the User Guide.
For your printer you can use the following types of paper and other media.
??  Size
• Standard paper: From Legal size (8.5 x 14.0 in.) to A5 size (5.83 x 8.27 in.)
• Non-standard paper: From 3.54 x 4.72 in. to 8.5 x 23.0 in.
• Others: Envelopes (US Com. #10 and European DL)
Important ?ž₪ Do not use the following types of paper. Using such paper will not only produce unsatisfactory results, but can also cause the printer to jam or malfunction.
• Folded, curled or wrinkled paper
• Wet paper
• Paper that is too thin (less than 17 lb.)
Paper that is too thick* (more than 28 lb.)
• Picture postcards
• Postcards with an affixed photo or sticker
• Envelopes with a double flap
• Sealed envelopes
• Envelopes with an embossed or treated surface
• Paper with holes (such as loose-leaf paper)
* non-Canon branded paper
??  Weight
17 to 28 lb.
Do not use paper heavier than this (except for supported Canon-brand media), as it
could jam in the printer.
??  Types
The following types of media can be used. For more information about the media and the
printing methods, refer to the specific sections.
Plain paper: Refer to the printed Quick Start Guide.
?ž¡ Envelopes
?ž¡ High Resolution Paper HR-101N
?ž¡ Glossy Photo Paper GP-301/GP-301N
?ž¡ High Gloss Photo Film HG-201
?ž¡ Glossy Photo Cards FM-101
?ž¡ Photo Paper Pro PR-101
?ž¡ Photo Paper Pro PC-101S
?ž¡ Transparencies CF-102
?ž¡ T-Shirt Transfers TR-201
?ž¡ Banner Paper
If you are receiving a paper thickness error (are there lights flashing?) is the thickness greater than 28 lbs? You can refer to the User's Guide beginning on page 140 for infomration on error light patterns.
Have you set the Paper Thickness Lever properly? Looking at the printer from the front; To the left for normal paper; To the right for thicker product (e.g. envelopes, t-shirt transfers, banner paper).
Trust this is helpful. Please vote. :)
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/s_series/s520#ServiceAndSupport
Dec 16, 2010 | Canon S520 InkJet Photo Printer
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
What the meaning of the error cs500 ?
Main motor Lock error:
Causes:
• Main motor defective
• Too much load on the drive mechanism
• Motor driver damaged
Oct 11, 2010 | Ricoh Aficio 1013F Copier
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Canon MX300 Office All-In-One Printer Logo
98 people viewed this question
old marine
old marine
