Question about Dell Inspiron 2600 Inspiron 2650 DVD Drive 4X730- 04X730 CD-ROM Drive
Dell inspirion 2650 does not see the CD/DVD drive, claims there is no driver.
  • celestia534 Jul 15, 2009
    Gee...thanks for assuming I am so stupid I hadn't already done this as well as a number of other obvious likely fixes.
    Useless answer, buddy.
Celestia534 - i share your sentiments. have you looked into running regedit and taking out the upper and lowerlimit files. didn't work for me. i've tried fixing this damn thing for years and no luck. it happened after the driver was updated but either way, i think i'm finally going to buy a used one. yeah, sux. now that the laptop itself is only worth twice that much.
mine recognized in file explorer and makes it through the troubleshooting finely. but when i try to use it, "NO HAPS."if i try to update it or install it using a software from the web, "driver is not connected."
if you know how to fix this, let me know. my email will alert me you responded to this, i think. if not, i'll just get the used one. man, and i only need to use it long enough to install linux on it.
Posted on Feb 02, 2010
  • 77 Answers
Well buddy try this step and it should resolve. right click on Mycomputer>leftClick on Manage>OnlefthandSide of the new window Click on Devicemanager>right Click on ur DVD Drive >Click on uninstall.restart it Should Find its Own Drivers.
Posted on Jul 14, 2009
Disk wont eject from inspirion 1720
cd drive right? might be jammed in there should be a small hole in side or front panel to eject manually might need to remove from desktop and do it that way. not easy
May 14, 2012 | Dell Inspirion / Studio / Vostro / XPS...
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
I am trying to install esx 3.5 from a usb on a poweredge 2650 and have not been succesful. any thought?
Hi Dell poweredge 2650 dosent support usb boot
try using a CD or DVD or floppy if you can get 1 big enuf
Sep 30, 2010 | Dell PowerEdge 2650 Server
Windows 98 on dell inspirion d600 install problem
Installing Windows 98, is you need a start-up disk (floppy disk) first before you can use the Windows 98 cd. The start-up disk will perform the partitioning and formatting of the HD...doing this, you have to boot from floppy drive first---after partitioning and formatting, you have change again the boot sequence to boot from cd then you can start the installation of Windows 98.
Jun 07, 2010 | Dell (6T980-A01) CD-ROM Drive
My Dell inspirion 2650 won't charge.
Try using a different power adapter. They sell for around $25 and up on the internet. Dell adapters burn out quite often.
Jul 30, 2009 | Dell Inspiron 2650 Notebook
I have a Dell Inspirion E1505 laptop and when I put a CD in it won't load. It just clicks and finally shuts off.
then the system cd player may be corrupted ,try and change it,if it persist then you can now format your system.
Jul 17, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dell inspirion 2650 does not for mat hard drive it
you might have to Debug and then format the hard drive heres the link for debuging the harddrive and then try to format..hope this helps.
http://en.community.dell.com/forums/t/19020652.aspx?c=uk&l=en&cs=ukdhs1&s=dhs
Regards,
Khushroo
Mar 09, 2009 | Dell Inspiron 2650 Notebook
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
Cant even READ DVD
the XP driver really should work appropriately. I might assume that the drive is damaged (which happens to me frequently with older DVD drives).
Oct 30, 2008 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
CD rom
hmm i would try unistalling the drivers then restarting the pc. there is a really good chance it is the drive. and yes you can get a dvd r or dvd rw if you can find one that will fit in the ssame slot
Apr 29, 2008 | Dell Inspiron 2650 Notebook
Computers & Internet Logo
105 people viewed this question
Alun Cox
