Question about Sansui RZ-5300AV Receiver
Phono section develops a loud popping in the right channel. All other inputs remain quiet. Cap on the phono board?
2 Suggested Answers
  • 49 Answers
SOURCE: how can i connect my pc to a sansui R-950AV receiver and then to speakers ?
Connect it to the (Auxillary) Jacks,
Posted on Dec 02, 2012
Why does my UREI 1620LE hiss on phono channels and aux 4 channel ?
are you using a phono pre on the phono channels?
Sep 15, 2014 | Music
Turntable troubleshooting
A loud hum is usually from an earth problem (in fact 'not earthed')
So your best bet seems to try the 2nd pre-amp again, and see if there is a pin or connector for an earth link. Mine earths to the chassis of my main amp.
Jan 31, 2014 | Audio Players & Recorders
SONY PS-LX56P turntable sounding very quiet when attached to a mini Sony hifi, even though our other turnable sounds fine on it.
Not knowing the electronics I'd imagine a close listen would reveal it's actually tinny as well as quiet. You probably need a Phono Preamp (Google it).
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jun 29, 2011 | Sony PS-LX250H Turntable
Connected new polks to cambridge audio amp a1 (about 30 watts per channel) and play cds through a panasonic dvd/cd player, but i can't turn up volume past 1 without it sounding too loud. sound is ok, but...
Plug the player in somewhere else besides the PHONO input.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it because old-school turntables require it to preamplify the tiny current produced by a Phono cartridge.
I imagine if you REALLY listened hard to the result you have you would find the bass is WAY too.
Google 'RIAA curve' to understand why.
http://www.graniteaudio.com/phono/page5.html
Mar 28, 2011 | Audio Players & Recorders
My Pioneer PL-990 Turntable only outputs sound through the white wire. Only a quiet buzz comes through the red wire.
The red wire is the right channel, so going back to your amp, get a single phono plug with with the wire exposed, so you can touch the wire. Then remove the turntable connections. With the amp on plug the the lose wire plug into each channel and check if the sound on the right is still low. If it is then there's a problem with the magnetic cartridge pre-amp inside the amp. They are often located near the phono socket on a seperate PC board, but if not just follow the red wire to the main board. Chances are it will be an IC that's failed.
If it has a strong buzz at the back of the amp. Then I should replace the wire between the turntable and the amp. Or the right phono plug that connects to the amp.
Nov 13, 2010 | Pioneer PL-990 Turntable
Loud distortion through phono inputs
Phono inputs are designed for turntables only. Any other device will provide too high a signal for that input to handle. The phono input has an extra amplification stage built in. The distortion is because of the high suignal level being supplied to the input. The only way to get this to work properly is to purchase an antenuator which will decrease the signal level to the phono level.
Dan
Dec 18, 2009 | Denon Audio Players & Recorders
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Jul 21, 2009 | Audio Players & Recorders
McIntosh MA6100 integrated Amp Phoho input crackiling
These units are capacitor coupled between stages. It sound to me like one or more of those caps are defective. There is an extra stage of amplification for the Phono inputs. Check the phono pre-amp section for defective caps. Dan
Jun 08, 2009 | Mcintosh MC602 2-Channel Amplifier
Sansui RZ-5300AV Receiver Logo
61 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
