Question about Qca Spas Majestic Series Aruba Xl Hot Tub
I cannt trun on my great lake hot tub it is flashing OH
  • 37 Answers
Either filter issue or temp sensor
Posted on Oct 11, 2009
Great lakes hot tub humming sound
You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
The power went out in town, the power came back on, and the power is on to the hot tub, but we got an F2 code, and it isn't going on to cycle and the temp is at 54 now. What is the F2 code. We have a great...
I need to know what kind of control pack your tub has. If you can open the side panel and tell me what brand the pack is I can tell you what the error code is for.
Nov 03, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Our great lakes spa digital display flashes ''OH'' after a few seconds
sound like you probably have a bad temperature sensor, or high limit sensor. "OH" usually means overheat and will shut the heater off. Have the sensors tested and go from there.
Nov 08, 2009 | Pool & Spa
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
I have a Great Lakes spa hot tub and nothing turns on, setting was saying OH. We turned the breaker off and then back on and now it is saying 5n.
OH MEANS OVER HEAT AND THE 5N WHICH IS ACTUALLY SN IS YOUR SENSOR SO IT WOULD NEED TO BE REPLACED SO YOULL NEED TO CALL A POOL AND SPA COMPANY FOR EXAMPLE..... HOTSTUFF SPAS&POOLS SALEM,OR
Sep 29, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
602 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
