My PC monitor shows blurred display immediately for little time when it is switched on.How to overcome this?
4 Suggested Answers
  • 62 Answers
SOURCE: monitor display blurred by vertical
1. cleen the G4 wire ( rust )
2. Change the neck base.
3. Adjust the Focus preset.
Posted on Nov 19, 2008
  • 62 Answers
SOURCE: On Screen Display Lock Is Blinking in the monitor all the time
1. Replaced the control panel Micro switchs.
Posted on Dec 15, 2008
marketex
  • 371 Answers
SOURCE: LCD Monitor does not start up with PC
We aim to please.
You aim, too, please, rate accordingly.
Posted on May 08, 2009
My laptop doesnot gets on only power n touchpad light turna blue nothing is displayed
I would try to plug in a monitor to the laptop. If the monitor works then you know that the LCD screen or LCD inverter is bad. If the monitor does not work the it could very well be you intergrated graphic is bad. Maybe also try to push the function button to switch from the laptop LCD to an external monitor a couple of times and see if anything happens.
Sep 29, 2013 | Samsung Laptop R480 Intel Pentium...
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Montor is blured with horz lines
The monitor or lcd screen is probably going bad or the video card inside the computer is bad. To isolate the problem try connecting an external monitor to the laptop. Borrow a Monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the blur and lines, then your lcd screen is bad and the video card inside the computer is good. If the Borrowed monitor displays the same way as your lcd screen with the blur and lines, then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Computers & Internet
What is the error code for blurd monitors]
I believe there is no error codes for blurred monitors. It just display the blurred of your monitor. And you have to change it.
Jul 09, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Blurred icon graphics
This is usually caused by windows display properties is operating incorrectly. One of the options is to default everything under your display options using control panel. If it still is blurred then try using the optimized screen resolution and enable the cleartype in Windows. If after doing that.. it remain blurred, try to use the Cleartype Tuner by Microsoft at http://www.microsoft.com/typography/...ePowerToy.mspx
See also http://www.microsoft.com/typography/...ner/Step1.aspx
Hope this helps. Let me know.
Mar 29, 2009 | Samsung SyncMaster 793DF 17" CRT Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Blurred picture
Have you tried lowering the Screen Resolution and Screen Refresh Rate of the PC in its Display Properties?
It could be that you PC's current settings are way above what the Samsung can handle.
Good luck and kind regards.
Thank you for using FixYa
Mar 22, 2008 | Samsung 793S 17" CRT Monitor
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Computers & Internet Logo
292 people viewed this question
David Payne
David Payne
