Question about Toshiba Televison & Video
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
I see tiny horizontal lines are appearing on my 46" TV and when I play a video game on the PS3 the image stays there and sometimes it takes a while to fade out. Stays like a photo. Also some white bands are appearing vertically whitening those area. Please advice.
    Top Expert:
  • Toshiba Master
  • 76,046 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 07, 2015
SOURCE:
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    My magnavox tv has sound but only a white line
    You have a bad ground or even a bad vertical IC. Have a tv tech pull the board out and inspect. It could be bad grounds and resoldering them may restore the picture. Also remember to check all capacitors in the immediate area of this IC, bad caps will heat up the vertical IC, and cause bad grounds. Replace the caps and Vertical IC as needed. Should be a standard fix in this case. Thanks for asking!
    Apr 25, 2010 | Televison & Video
    Exact same problem on 47" Regza: multicolored vertical lines
    If you wish to get some details; visit the site linked here. Pull up older posts.
    Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
    Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
    Apr 23, 2017 | Toshiba REGZA 47HL167 TV
    My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
    Hiii fairley,
    You aren't specsificly dercribe yor tv set.
    For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
    For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
    Tha's what all I know....
    Hope can help you to solved the problem.
    Thank's
    h3liax
    Jun 22, 2009 | Toshiba 32A33 32" TV
    No picture no sound
    Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
    If that is the case, maybe vertical IC failed or loose connection.
    Apr 05, 2009 | Toshiba CF32H40 32" TV
    2 in. band at the top of my Toshiba 32" Tv is distorted. No adjustments worked. Thought it was the change to dtv, but this is the only tv in the house that's affected.
    well is the band white or black and clapsing it may be in the vertical curcit also does it do it w/out dtv converter box hook it back up the way that it was see what happens sorry
    Apr 03, 2009 | Toshiba 32A14 TV
    Green line on each side of the plasma display.
    Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
    Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
    Two vertical lines one at 1/3 screen the other at 2/3's of screen
    I have not fixed it yet. But I have identified the chip that is causing the problem. If you have a service manual scan it and post it please, so I can show you the chip.
    Aug 04, 2007 | Toshiba 57H81 57" Rear Projection...
    Televison & Video Logo
    146 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
