Question about Garden
Toro lawn mower. Have trouble starting(starts and
Toro lawn mower. Have trouble starting(starts and stops). Sputters and surges after starting. Could it be spark plug or air filter?
    President:
  • 1,129 Answers
Remove the float bowl located under the carburetor it is a 1/2 bolt some gas will poor out so put a rag under the carb to soak up the gas, you actually may want to use a small container to collect the gas or make sure the gas tank is empty, remove the float bowl after removing the bolt by grasping it and turning, the bowl will most likely have debree and water in it clean with a rag and solvent and reinstall, becareful of the ruuber ring gasket when reinstalling the float bowl, one some movers there is no float bowl if you have this type of engine the tank and carb must be removed disassembled and clean out. Do not store mowers uncovered they must be covered when not in use, water gets into the fuel system and causes this problem.
Posted on Jul 14, 2009
TORO MOWER PROBLEM
sounds like your carburetor might be given out. Check your spark plug first to make sure its not burnt out.
Aug 14, 2012 | Toro Power Lawn Mower
Will not start toro model143.026706
if it stopped running after hitting something with the blade check the key on the flywheel where it meets the crank
Jun 04, 2012 | Toro Power Lawn Mower
My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
May 01, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 6.5HP lawn mover it starts the it stops.
CHECK FOR WATER. DRAIN TANK AND REFILL MAY HAVE TO DRAIN CARB
Sep 24, 2009 | Toro Lawn Mower With Toro Power Tools
Cannot re-start lawn mower!
Take it back where you bought it and let them deal with it.
Sep 13, 2009 | Toro Lawn Mower With Toro Power Tools
Engine surging
sounds like it is "hunting". it is a fuel mixture issue.
May 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
258 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
