Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
  • 25 Answers
Sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Posted on Jul 16, 2009
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
Replaced the lid switch on my top loading washer and it fills with water and it still wont start.
There are a couple things that could cause that
1) The water level switch,but if it filled to normal level and the water stopped that is pretty unlikely.
2) the motor,if it just sits there silent and no humming/buzzing noise the motor is most likely not the problem,if a heavy buzzing is heard the motor needs to be replaced.
3) again if it just sits there and wont make any sounds no matter where its set at,the timer is the very probable trouble.
I hope this helps you diagnose your washer trouble,
Gene
Aug 05, 2011 | Washing Machines
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Machine makes a buzzing noise and does not start when turned on
The buzzing noise could be the water inlet valve which is quite normal. Make sure the water is turned on, If it is, Turn off the water at the tap and remove the water inlet pipe from the back of the washing machine and check that the filter inside is not blocked. Other than that, it could be the vavle itself that`s not opening to let the water into the soap dispenser. Ian
Jul 25, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Fills but nothing else
if you hear a buzz ... is it a motor noise? check if it will drain... if it will drain you problem is the motor coupler ..I can help you replace it get me in a chat.. Hope it helps
Sep 06, 2008 | Estate TAWS850PQ
Washing Machines Logo
490 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
