2000 watt baseboard heater is making loud clicking noise
The electric baseboard heater is mounted onto a wooden wall with four screws near the ceiling. It is connected to a manually-controlled Honeywell line-voltage thermostat. While the heating element is heating up, it generates a loud clicking noise as well as a low buzz, and once it has heated up, the clicking stops. When it is turned off and begins to cool, it starts to click loudly again.
  • 1 more comment
  • Anonymous Mar 01, 2008
    not getting real hot. making noise shortly after being turned on.
  • paulmw Mar 25, 2008
    When my heater is turned on and heating up, it makes banging and clicking noises. It is a regular metal baseboard heater that is attached to the wal. How do i solve this problem? Other hearter in the house do not do this.
  • Vee_2828 Mar 26, 2009
    honeywell heater mounted to wall makes a clicking noise when turned on
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Posted on Oct 31, 2008
    Problem Solver:
  • 5 Answers
You do not give details as to the material the heater is made of.If we presume the backing is made of metal then the heat is deforming the metal and being screwed there is no expansion.Also why is the heater on the ceiling.Dust and other grime will give a smell-keep it clean.
Hope this helps
Posted on Nov 17, 2007
This heater is a 2000 watt garrison convection wall mounted heater. the light is on but the heater does'nt heat up
The heater is disconnected or there is a damaged wire. You can try to open it up or bring it in. I would suggest bringing it in for repairs.
Elisa Jed '
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Sep 29, 2009 | Fahrenheat Electric Convector Baseboard...
Thermostat for Fahrenheat 5000Watt Ceiling mount heater
You could do it. It would mean serious wiring though and you should use the factory thermostat because it is designed to operate on 240 Volts. Or you could use a remote thermostat at low voltage to throw a relay in the heater and get it to come on. The manual has good diagrams on how it is wired and it would not be too hard to do. IT would operate just like the outside unit on an HVAC system .
Oct 26, 2017 | Fahrenheat Electric Convector Baseboard...
Installing hot water baseboard heater
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
Heating & Cooling Logo
2,007 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
