Question about Vivitar VIVICAM 7388 Digital Camera
Where is the battery compartment - Vivitar VIVICAM 7388 Digital Camera
    Scholar:
  • 95 Answers
Its so simple,just slide through your manual..
or defintly it will be in the LOWER part of the camera with[ (=>)to open ] symbol look closely
rate me!!!
Posted on Jul 14, 2009
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Just replaced batteries camera is brand new and wont turn on
    Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
    Jul 18, 2010 | Canon PowerShot A490 Digital Camera
    Opening battery compartment on Midland LXT80 2-way radios
    First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
    Jul 07, 2010 | Midland LXT80 Two Way Radio
    Looking for battery compartment
    Your battery compartment is more than likely located in the back of the unit underneath the mounting bracket. You need to remove the mounting bracket in order to gain access to the battery compartment.
    You can find your manual here:
    http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_29897ge1_29897ge1.html
    But it doesn't have any reference to your battery compartment for your phone. That I could find anyway.
    Feb 10, 2010 | GE 29897GE1 Corded Phone
    Vivitar VIVICAM 7388 Digital Camera Logo
    57 people viewed this question
    Top Vivitar Cameras Experts
    Tony
    Are you a Vivitar Camera Expert? Answer questions, earn points and help others
