Question about Nokia Cell Phones
The navigate button wont let me go from side to side anymore, just up and thats it ...can I take the silver bottem piece off safely without breaking my phone any more?
Drum error light is on
For the error you described however you would need to check and clean the contacts for the drum on the left side of the inside of the machine.
if it's a drum life error then you either need to replace it and/or reset the counter.
to reset the drum counter, open the front cover, hold down the start button until all lights come on, then release the button and shut the front cover.
Pull the drum cartridge apart to clean the charge assembly properly, it's very easy to pull apart. just make sure you don't break the corona wire in the process.
The printer has a light sensor on the drum/cartridge in the middle of the right hand side (assuming your facing the printer) - its a little circle /window that it uses to check for light. If you cover that with something that doesn't let light in (A small piec of cardboard etc) then you wont get that error anymore and you'll print happily ever.
Feb 23, 2011 | Brother HL 2140 Laser Printer
My son stuck a small piece of foam into the seat belt latch assembly and buckled himself in. Now seat belt will not unlatch. How do I disassemble the latch unit to get the piece out?
Boys! If my 12 year old can't break it, it must be indestructable! I can't see a safe way to remove the plastic casing without breaking it or damaging the integrity of the buckel. I suggest that you use a shim to push the foam furter down into the buckle housing away from the internal latch. I just tried this on my toyota and used a 0.50mm feeler gauge (auto store) and was able to work around the front, back and sides of the release button down into the housing. It was stiff enough that I believe that anything in its way could be dislodged. I didn't want to replicate the foam jam, but I believe that with this shim I could dislodge the area around the latch hole enough to push the button and release. Then you can use tweezers and the shim to remove the foam. Good luck!
Mar 15, 2010 | 2007 Toyota Sienna
Track ball on my blackberry is stuck wont go up and now it just goes down i can't navigate.
take off the silver ring over around te ball it should just pop off and clean the entire ball piece that comes out
Nov 05, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My iphone wont respond to my touch in the bottem halk
Have you tried doing a hard shut down? Hold the silver button down on the upper right corner and also the home button (center,bottom indented button) together for about 10 seconds. the phone will completly shut off. then wait about 10 seconds and hold down the upper right hand button until the apple appears on the phone then release the button and wait (20-30seconds) . Doing this usually solves all my issues with my iphone when it gets locked up like this.
Jul 01, 2009 | Apple iPhone 3G Black Smartphone
Lost the keys
easy and it wont break your safe. just get a flat head screw driver shove it in the corner of the top black handel bar and pop it out. safe will open, when done place the bar back in.
Apr 29, 2009 | Sentry Fireproof Safe
The sunroof on my 2000 mercury cougar won't close completely
you will need to hold the glass why you hold the button to close need more info go to collisionrepairadvice.com
Apr 04, 2009 | 2000 Mercury Cougar
My gun fell apart
sell it to me to fix my gun I need the left grip and the rotory cylinder magazines Do you have these items?
Mar 05, 2009 | Crosman Phantom .177 Caliber Break Barrel...
How to change the faceplate on the ti-84 silver edition
Look at the bottom of ur calculator. not the back the bottem. and u should see where the gray area meets the white area. There should be a small lip at the bottom of the calculator. Pull back the lip, it should come off with minimal force. That is how u remove the faceplate
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
Nextel i880
my phone does not display menue anymore
Jan 15, 2009 | Motorola Mobility i880 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
