Question about Fargo DTC510 Card Printer
We have a Fargo card Printer and it won't take the ribbon. It keeps saying there is no ribbon
  • Jeff Wibbenmeyer May 11, 2010
    First I need to know what model the printer is. It could be that the ribbon sensor has become misaligned on has gone out Knowing the Model will help me to troubleshoot it with you.
    Problem Solver:
  • 5 Answers
It sounds like your ribbon sensor is dead, and needing replacement.
Posted on Jul 20, 2009
Persona C30 Thermal Card Printer: im using fargo printer 30e. everytime i tried to ...
How many prints have been down on the unit?
the most common problem could be the rollers need replacing or a problem with the ribbon sensor. We do repairs and also repair under warranty, How old is your printer?
thanks
May 16, 2010 | Fargo Persona C30 Thermal Card Printer
DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
My Fargo card printer is eating up ribbon cartridges. I only have one left and they are expensive. Please help
Clean the printer using fargo cleaning cards. Then calibrate the ribbon sensor. Their is a Diagnostic button in the printer driver
Mar 09, 2010 | Fargo DTC510 Card Printer
I have a persona C30 card printer by Fargo and it keeps telling me that the ribbon is broke when in fact it isn't....I put in a new ribbon cartridge thinking maybe I had a bad ribbon, but that doesn't seem...
run forgo diagnostic utility given on your installation cd
Try by doing all the tools under mechanics tab most importantly ribbon sensor calibration and advance & reverse ribbon drive motor by removing the ribbon as instructed by the manufacturer
Jan 06, 2010 | Fargo Persona C30 Thermal Card Printer
Fargo HDP5000 HDP5k H5k Ribbon Breaks Error 97
You need to update the printers firmware. 9 times out of 10, this is the issues I see.
Go to HIDglobal.com. Under the support tab, select Drivers & Downloads. From here, populate the drop down menus with Make and Model. Compare the available firmware with the firmware version current installed on the printer.
Hit [Options] then [Next] on the printer to figure out the version.
On this same web page, make sure to download the Fargo Workbench Utility. It gives you the ability to update.
Aug 06, 2009 | Fargo HDP5000 Thermal Printer
Printer keeps breaking the ribbon
first, try to calibrate the ribbon, if it does not work, you probably have worn out rollers, and possibly a broken o-ring. if you want more info, call us at 310-671-8018, thanks adi
Mar 25, 2009 | Fargo DTC400 ID Card Printer Package
Ribbon mis-cue?
When you have a ribbon mis-cue, first remove the ribbon. Go to the printer driver, printing preferences, calibrate, sensors. Click sesors then send... You should hear 2 beeps. Put you ribbon back in and try to print again.
If you still have the mis-cue it is a belt issue all DTC400's made 2006 and prior have had this belt issue. I don't recommend fixing this yourself, send it to a authorized Fargo repair center. This way it is under warranty.
Jan 05, 2009 | Fargo DTC400 ID Card Printer Package
Bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
Fargo c16 card printer
it is time to upgrade your printer
Mar 06, 2008 | Fargo Persona C16 Thermal Printer
Fargo DTC510 Card Printer Logo
117 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
