Question about Back to Basics Kitchen Appliances - Others
Our Soho toaster will not let the bread stay down in the toaster - it pops right back up - have to hold down the lever to toast anything. what can we do? jm
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
szwaan
  • 209 Answers
SOURCE: Bread won't toast
Try pushing it down with more force
maybe check the manual or maybe theres a switch to make it stay..
Posted on Dec 27, 2007
SOURCE: My toaster doesn't stay in the down (toast) position unless I hold it down
I had the same problem with this model. Made sure it was unplugged, took the 4 screws out of the bottom as others did. Pulled off the handle for the toast push down and the knob for the darkness control (it took some effort but came off ok, if you can tilt the darkness knob opposite the number 1 it will come off easier, there's a hook-tab right at the 1 position).
My problem was with one of the points on the 4 copper tabs that come together as the toast is pushed down. The outer copper tab was slightly out of alignment when the toast was in it's latched position and broke the circuit making it never want to latch. I bent the problem one into alignment and solved the problem.
Posted on Jan 01, 2008
  • 71 Answers
SOURCE: My toaster is hung up on '2'...and flashes. I just want a peice of toast!
Certainly seems like it's last day has gone!!
It did give you good reliable service didn't it !!!
Posted on Jun 04, 2008
SOURCE: Digital Display no longer showing, lever won't stay down
YOU HAVE A DEFECTIVE DIODE THAT LITES THE LCD. A .99 CENT PART. SELLER SHOULD REPLACE THE TOASTER WITH OUT QUESTION.
Posted on Sep 30, 2008
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
Just got 4 slice de longh iconai toaster and husband made toast last night in right hand side. No problem last night but this morning this side will not toast as the lever which one pushes down to keep...
I have no experience with the deLonghi toaster but in my experience automatic toaster all work in similar ways since they went electronic - toasters were about the first to do that.
Pressing the lever down against the spring pressure also presses an internal switch that sends current to the heating element as well as to the electronics that control an electromagnet, the purpose of which is to keep the mechanism engaged until the toast is brown enough and then the current to the magnet will be cut by the browning brain and the toast pops up.
If removing any crumbs from inside by inverting it and giving it a good shake and then pressing the lever a few times fairly vigorously doesn't make it work then nothing short of surgery will make it work so returning it will be the only realistic option.
Aug 22, 2017 | DeLonghi CTO4003 4Slice Toaster
My toast willl not pop up to retrieve it sits lower than the toaster
I have the same problem with some breads. Mine is also set up for bagels, and the bread goes further into the toaster. When it pops up, it then drops back down just enough where I'm not about to stick my fingers into the darn thing......sound familiar? The only thing that I've found that helps is that, when the toast pops up, and then drops back down, I lift up on the lever that you push down to start the toast, and I can lift the toast up about an inch, and safely remove it. Try this, and see if it works for you.
Best regards, --W/D--
Apr 09, 2011 | Vacuums
Just got this toaster, and when i tried it out for the first time the lever would not stay down it kept popping up.
Is there any 'temperature' setting that needs to be adjusted higher, to make it stay?
What did the manual say about how to toast your first slice of bread?
It sounds like you might need to take it back, and get it replaced.
Tell us more--
Mack B
Dec 27, 2010 | Black & Decker Black Decker T2560B 2Slice...
The lever won't stay down
The lever will not stay down. Sometimes the lever will catch and other times it takes 6-8 times befroe it will stay down and toast the bread. Thanks....
Oct 16, 2010 | KitchenAid KTT570 4-Slice Toaster
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Lever on taoster will not stay down
I would just buy a new toaster...they are not that expensive. Check the intruction book first because maybe it's under warranty. Or if you bought it very recently, just take it back to the store. Most places will take it back even without a reciept if you tell them you just bought it and it's already broken.
Nov 22, 2008 | Kitchen Appliances - Others
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Back to Basics Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Pierre Legault
Marks concession...
Marks concession...
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
