Question about Ranger TR-966 CB Radio
How do I set the clock on my Ranger professional with Blue Tooth
How do I set the clock on my Ranger professional PPR-RBT1. It has blue tooth and I can't figure out how to use the Blue Tooth part of it. It says the volume buttons control it but not how to do it.
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
Posted on Aug 29, 2009
How do i shut the blue tooth off of my texas ranger radio without using the orginal mic.
Posted on Feb 08, 2011
How to Sync Clocks With my Computer?
press the blue tooth on the clock and discoverable on the other
if the isnt a blue tooth then you ll have to get ablue toothpart looks like this
its called xtreme blue tooth
Oct 20, 2016 | Computers & Internet
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
Where can i get the ranger professional bluetooth ppr -rbt1 repair?
if its still under warrentee then send it back to where it was made. If not send it to a place like Bells cb in Fl. or another reputable shop. Inquire with them before you send it to them and they will tell you how to send it.
Feb 13, 2013 | Ranger TR-966 CB Radio
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard Hp...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
Headsets with blue tooth to my P.A
Blue tooth is not used for professional audio for many reasons.
Sep 08, 2008 | Shure SLX UHF Headset Wireless System...
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Radio Communications Logo
557 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
