Question about Jenn-Air JCD2290HES Side by Side Refrigerator
My Jenn Air JDC2389GT is 5 years old. Two years ago it stopped cooling and a new motor was installed under the warranty. This week it stopped cooling again. Is it worth fixing again or should we just scrap this model and buy a new refridg? Thanks.
peyton32034
  • 410 Answers
SOURCE: Jenn-Aire JCD2389GES Side by Side: Frig not cooling fully - freezer fine
i'm thinking that maybe an air duct is either blocked or the damper isnt opening. In the freezer compartment at the top right side there is a cover that is held in place by 1 screw. (look at item number 35 here). remove this cover and make sure ice is not blocking it up. if that is ok, then check the damper control to be sure it is opening and closing properly. The damper is located on the refrig side in the control cover (look at item# 8 here).
Posted on Dec 18, 2007
the dr
  • 447 Answers
SOURCE: jenn air french door refrigerator broken by repair company
Ill be glad to shed some light on this for and stand behind this as I too am a Factory authorized dealer. These units did come with faulty compressors failing about 80% of the time. What happens is the compressors get worn and stop starting properly. You can make them work temporarily by installing a 3n1 (basically makes the compressor have more starting torque). However they eventually get so worn that even a 3n1 cant start it. Ive never read any bulletins from any major company (Frigidaire used this same compressor) saying a 3n1 voids warranty. It certainly didnt damage the compressor it was already damaged when the tech installed the 3n1. Also these compressors are failing at such a high rate its not even questionable that the 3n1 damaged anything. Honestly it really sounds to me like the tech is nit-picking not wanting to do the labor intensive job of changing the compressor. He may not even be able to. Also the new compressor should be a 8201555 (I just did one this afternoon ---thats how common this is) and its a much more reliable Embraco compressor. Once its installed you should have no more compressor issues for many years. Feel free to have anyone who questions my solution to call anytime 850-510-9563 (Joey Shearer, Precision Appliance, Tallahassee, FL)
Posted on Jan 15, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
mikedurland
  • 481 Answers
SOURCE: Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
it sounds like a bad: start switch (on the side of the compressor) or compressor itself the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Aug 08, 2008
SOURCE: JennAir #JCD2389GES not cooling refrig at all.
I believe I solved my own problem. First, I defrosted the coils on the freezer side. This is done by turning off power to the refrigerator and using a hair drier to defronst. This takes about 20 minutes. To open the panels, unscrew the top two hex head screws just slightly. Then unscrew the next lower two hex head screws all the way and remove two panels revealing the frosted coils and the fan. It is easy to unscrew these using a screwdriver-type wrench. As the defrosting takes only a short time, I did not have to throw away any food. We have this same refrigerator in two houses, main house and vacation house, and I have used this method a couple of times on each refrigerator. The problem arises when, in warm weather, someone leaves the door open. One time it happened because a cardboard case of 12 oz sodas was preventing the door from shutting all the way. For that particular box, which is used in CocaCola products, you have to put the back of the box over the top of the shelf ridge; otherwise the box protrudes a bit too much in the front.
The above method did not work completely the last time I tried it. There was a warm spot in the middle of the rifrigerator side while the freezer side worked okay. To fix this new problem, after checking all coolness settings, I removed the assembly in the top of the refrigerator side--the control temperature control unit. The temperature control assmembly is mechanical and consists of just two levers that control the flow of air from a vent in the upper left corner of the refrigerator side. (My unit has the freezer on the right hand side.) The levers (for refrigerator temperature and freezer temperature) just open and close the vent. Another vent on the left middle of the refrigerator side controls flow to the middle. I had already opened this. When I loosened the temperature control assembly (four hex-head screws and two Phillips-head screws), I discovered that a piece of styrofoam had lodged in the air passageway between the freezer section and the refrigerator section. I removed this.
Unfortunately, I inadvertently broke off a plastic tab holding the canopy that covers the temperature control assembly. This caused me to do a lot of swearing. Nevertheless, I overcame the problem by purchasing a small shelf support that screws into the rear panel of the refrigerator. These are available on-line or from an appliance store. To avoid breaking off the tab, gently pull the canopy forward to allow the tabs on each (rear) side to be disengaged through two rectangular holes in the canopy. Gently work the tabs through these two holes.
After working on the canopy for awhile, I was afraid that the freezer coils may have gathered some ice. If so, I would have to re-defrost these. All was okay though.
One more thing: be sure that there is room for air to flow near the top shelf of the refrigerator. Stacking up too many things on that shelf deflects the airflow. When trying to get the refrigerator side working correctly, I removed everything from this top shelf. Cooling was perfect, so I added a few items to the top shelf, and everything continued to work just right.
Yet another thing: I figured out that the noise I had noticed came from the filter bottle that had outlived its usefulness. Rather than buy another filter bottle, I just ordered two dummy filters. I have given up on the actual filters because they cost $50 apiece and last for about four months. I can't taste the difference either in Los Gatos California, or Tahoe City, California. Of course, I had thrown away the dummy filters for my two refrigerators, but I was glad to see that these can be ordered on-line.
Posted on Oct 15, 2008
Jennair jsp42ppdbda faulty evaporator drip pan - leaking down into freezer compartment
I've got the same problem. After installing a replacement drip pan (W1019913) and disconnecting the thermistor per the enclosed instructions, the problem returned within two months. I just called Jenn-Air customer service and was told that there is a new design for the drip pan this is only available through Jenn-Air, and not through distributors. Therefore the part I purchased in November through a distributor was the old design (even though it was dated 1/27/11).
The Jenn-Air rep agreed to have a tech install the new design under warranty, even though I purchased the unit almost 5 years ago. I'm hopeful that this will correct the problem.
If you still want instructions on how to remove the drip pan, let me know. But I would return the part you've got and ask Jenn-Air do it for free.
Dec 14, 2011 | Jenn-Air JCD2389G Side by Side...
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
My right front burner has stopped working.
no solution - just wanted you to know that I have had this model since 2004 and had to replace this burner twice under warranty and twice after that. It broke again 2 years ago so I just cook without it now. Will be replacing the cooktop and am resolved not to buy Jenn-Air/Maytag/Whirlpool products again - convinced it is a element design problem.
Feb 26, 2011 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
In installed a new complete 2 ton system and in ran fine for 4 weeks then the it stopped cooling! the air handler is still runing but the condensor stopped running.
Did you have a company install it for you? If so, then it should be covered by a warranty. Most contractors offer a 90 day to 1 year warranty on their new installations.
I recommend you contact the installing contractor.
Sep 04, 2010 | Haier Heating & Cooling
Fan cool fridge working 3years bought new 2days ago starts blowin
Good day,
I don't understand your caption..........
Fan cool fridge working 3years bought new 2days ago... However, it sounds as if the compressor is trying to start and cannot.
If the machine is under 5 years of age, the compressor is under factory warranty.
There is a relay, capacitor, and overload which are connected to the side of the compressor after removing the back bottom rear cover.
These items could be removed and taken to an appliance parts house, where they would be glad to test them for you. Replace failed parts.
However, if it is under 5 years of age, I would recommend you call for factory warranty service. They may have to charge you for one of these parts, but since it could be a failed compressor, and not the starting components it is better to let them service it and maintain the balance of your compressor warranty.
Jan 29, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
Freezer side working fine but refrigerator side not cooling at all. Has been like this for a week or so.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area..
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Refrigerators
hi thanks for the question if the tech did change the defroster 3 monts ago he probably changed the right part cause frost develop-es after 1 week depending on where you live if you live in a humid climate then the frost will build up faster so you could have another problem i would check the fan motor in the freezer it can cause this problem thanks the appliance doc
Sep 03, 2008 | Jenn-Air JCD2389G Side by Side...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
